d16z6 engine mount rubbing on timing belt
Old Sep 16, 2006 | 12:10 AM
mattie_96's Avatar
Default d16z6 engine mount rubbing on timing belt
I came across a website in the past that stated that you have to grind the d16z6 drivers side engine mount slightly in order to avoid the z6 timing belt from rubbing against the mount...I have never seen this but is it true?
ALso im using a y8 head on my z6(havent started it up yet) and im using the y8 timing belt.....this should be correct I beleive.
Old Sep 17, 2006 | 07:52 PM
jaycrxsi's Avatar
Default Re: d16z6 engine mount rubbing on timing belt (mattie_96)
I myself had no problem with the mount rubbing the timing belt as for the y8 timing belt I believe that is right don't hold me to that for sure
Old Sep 17, 2006 | 07:54 PM
mattie_96's Avatar
ya i would imagine it would be a factory recall if the stock belt was rubbin on the stock mount..i personally havent seen it just came across a website on honda swaps that referred to it
one-cam
Aug 15, 2008 08:11 PM
slor209
Mar 12, 2008 01:41 PM
BILLisCHILL
19
Mar 11, 2008 06:51 AM
Layziebtnh055
May 21, 2004 09:12 AM
SleepyHF
Apr 11, 2004 09:53 PM
