in dying help!!!...installed sub and car fuse keeps burning???
Old Sep 15, 2006 | 11:25 PM
-Championship-'s Avatar
Default in dying help!!!...installed sub and car fuse keeps burning???
tonight my friend installed a 10in RF sub and everything was done..turned on the car, the bass sounded good, everything was good, but to my surprise when i turned my headlights, the sidemarkers, taillights, and bumper lights. and gauges..didn't work!!!...
we checked all the fuses under the dash...none were burned...i checked the alarm and one fuse was burned (lights go on when alarm is triggered)....so we checked the main fuses under the hood and this one fuse that read..+5 SMALL i think it said..was burned...so i put a new one and the fuse burned that new one...it burned 3 in total...so what can it be????????.....anyone had this problem before?
Old Sep 16, 2006 | 02:03 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: in dying help!!!...installed sub and car fuse keeps burning??? (CW_98gsr)
more Info on your setup and were did you tag the wires. Is it a stock or aftermarket radio.
Old Sep 16, 2006 | 08:16 AM
fcm's Avatar
fcm
Old Fart
Was it fuse 51 - +B SMALL 15A, [hot at all times] in under hood fuse box?
Are fuse 30 - 7.5A, [instrument lights]and fuse 32 - 10A, [license/tail lights] [hot when light switch is on] in under dash fuse box, still good?
What is the sub amps power lead connected to, [where is the amp getting its power]?
When does the fuse in the under hood fuse box blow, [as soon as you put it in, or when you turn on the lights]?
Is it the stock alarm or an aftermarket one?
Is the HU stock or aftermarket?
The above assumes we are talking about a 1998 Integra GSR. 94
Old Sep 16, 2006 | 08:20 AM
redpeppers's Avatar
Default Re: in dying help!!!...installed sub and car fuse keeps burning??? (fcm)
where did you wire the amps "remote turn on lead"?
Old Sep 16, 2006 | 09:13 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Was it fuse 51 - +B SMALL 15A, [hot at all times] in under hood fuse box?
it will burn as soon as i put it in
they werent burn and i dont think it was hot
straight from the battery
as soon
aftermarket...and it smelled like burt, but still good, one fuse burned and replaced, and new fuse is good
??????????...dont know what is HU
The above assumes we are talking about a 1998 Integra GSR. 94</TD></TR></TABLE>
1998 gsr
oh and i have a kenwood stereo...forgot what model...hope all this info helps to help me
Old Sep 16, 2006 | 09:51 AM
Make sure the dimmer wire is not touching anything behind the headunit. And is either taped up or hooked up correctly
Old Sep 16, 2006 | 11:33 AM
Default Re: (wrx-killer-Sti eater)
please guys i need help
Quote, originally posted by fcm »
as soon
1998 gsr
Old Sep 17, 2006 | 10:15 PM
bpr0422's Avatar
Default Re: (CW_98gsr)
hu = headunit
noob j/k j/k
Old Sep 17, 2006 | 10:38 PM
Default Re: (bpr0422)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpr0422 &raquo;</TD></TR><TR><TD CLASS="quote">hu = headunit
noob j/k j/k </TD></TR></TABLE>
haha i know ima noob..well fixed the problem, thank GOD!!, i was never ever into sounds but it's getting to me, i see it as dead weight to me
i bought it cheap so hehe....depeche mode never sounded so better
Old Sep 17, 2006 | 10:59 PM
so what was the problem?
Old Sep 18, 2006 | 01:05 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater &raquo;</TD></TR><TR><TD CLASS="quote">so what was the problem?</TD></TR></TABLE> Ditto that, I also want to know what the problem was. 94
Old Sep 18, 2006 | 01:18 PM
Default Re: (fcm)
dont know, i think their was a wire that was touching ground or something
byc_cb7
Sep 28, 2009 02:45 PM
HondaTech101
Apr 7, 2007 06:59 AM
V-Thang
Acura TL, RL & ZDX
May 28, 2005 11:33 AM
jdmaek
Apr 2, 2005 08:29 PM
