Engine question(s)
Old Sep 15, 2006 | 04:57 PM
dra600n's Avatar
Default Engine question(s)
Alright, here's my situation:
I'm currently running an 89 CRX Si with a ZC DOHC that is start to die.. quickly.
Of course, I hadn't planned on it happening just yet, but I was expecting it as there is a cross threaded spark plug (didn't know until the engine was already in ) and then the anti freeze started magically disappearing (head gasket I believe)
So, I figure I have about $1,500 to spend on a new engine (including the cost to install the engine since I'm not entire mechanically inclined, nor do I have the proper equipment).
Now I've started doing some research, and a B16a is out of the question (engine + mounts + axles + installation = more than I can afford at this time)
My next idea was a ZC w/ VTEC, but as I'm starting to find out, or I'm just a moron, I believe they don't make them?
I was looking at a D15B 1.5 VTEC, since they go for roughly $500 after taxes, shipping, etc. My questions are
1.) What is the HP these things have
2.) Do they bolt right into the engine bay without mods/motor mounts
3.) Do I need to get a tranny for it, or will the CRX Si Tranny/Integra ECU work with it, or will I need to order it with the tranny + ecu?
Any information will be of great help.
Thanks
Old Sep 15, 2006 | 05:05 PM
Bjorn20's Avatar
Default Re: Engine question(s) (dra600n)
since your already setup with mpfi, you can EASILY do another d series swap for less than $1000.
for the zc vtec, ive never heard of anything like that, as far as i know the zc is a one of a kind motor. But i havent researched d series in a while
horsepower for a d15b vtec is ruffly 130@ ? rpm to the crank
yes it will bolt right in
the si transmission will bolt up to it. Pretty sure any d series transmission besides the one that came with the zc will bolt up to it. 90% positive its 89-91 d series are all good to go, but the 88 is the other one of a kind.
the ecu, either a p08 or a p28 will work
Old Sep 15, 2006 | 06:06 PM
dra600n's Avatar
Alright, thanks for the information. Is there any noticable difference between the D15B VTEC and the ZC DOHC? Which in your opinion is better?
Thanks
dra600n
Mar 18, 2007 05:02 PM
Jmpage
21
Feb 20, 2005 07:52 PM
vtec_head
11
Sep 11, 2004 07:56 AM
Renegade
13
May 17, 2002 11:10 PM
