Honda accord
Old Sep 15, 2006 | 02:53 PM
jojo69's Avatar
Default Honda accord
93, accord EX, 160K, automatic
Hi all,
if my car sits idle especially in the morning for over 2 minutes, it starts to studder. It chocks and it would not take any gas.
Also, If i run the engine for about 2 minutes with rmp at 3000, the same thing happens.
Any idea guys.
Thank you all and have a nice weekend.
Joe
Old Sep 15, 2006 | 03:10 PM
SlowCG's Avatar
Default Re: Honda accord (jojo69)
um not trying to be a dick, but dont run ur car at 3 grand for 2 mins straight.
Old Sep 15, 2006 | 05:02 PM
BlUAc's Avatar
Default Re: Honda accord (98AV6205HP)
ya 3gs for 2 min uur krazy sounds to me like your valve seals are leakin into your combustion chamber when it is sittin over night let me ask you when your at wot does blue smoke shoot out your exhaust if so my be a sign of piston rings failing
Old Sep 15, 2006 | 05:29 PM
jojo69's Avatar
Default Re: Honda accord (BlUAc)
I only ran the car at 3k rpm ONCE.
it was only because it is a part of the trouble shooting process. The trouble shooting manual calls for it.
Thanks
Old Sep 15, 2006 | 05:41 PM
hondadude's Avatar
When was the last time the plugs were changed?
From your description of the car runs at idle for a few minutes then stalls??
Could be a bad IAC valve letting thru too much air, or a major vacum leak.
I'd run that engine at 3000 RPM all day with out worry!!
Old Sep 15, 2006 | 06:25 PM
shadow_ridge's Avatar
Default Re: Honda accord (hondadude)
intresting my car just started doing something like that like a week ago. All i did is retightend the throttle. Last time I had that issue is when I had a vacuum leak trew the stock intake system. I would rev it to 2.5 sometimes 3.9 rpms and hold it for 20 seconds. The let go it will stuble to 550 rpm, then go back to 700 after 5 seconds.
If your like me I come to any stop sign or stop light it will stuble to 400 rpm then go back up after 7 seconds after the sound of a click noise(like ac clutch) but no ac on tho.
Old Sep 16, 2006 | 09:43 AM
jojo69's Avatar
how do you check for vaccum leak?
thanks
Old Sep 16, 2006 | 01:52 PM
BLKFLSH's Avatar
Spray some carberator cleaner on the hoses. When the leak sucks up the cleaner, it will expose it self. good luck
Alan Long
Jun 21, 2013 06:47 AM
Enixero
Sep 18, 2012 03:40 AM
Chief Wenceslaw
Sep 29, 2006 10:03 AM
