how high compression for stage 2 cams
i was wondering how high is the CR supposed to be for stage 2 cams. i'm goin ls-vtec with pr3 pistions and the ration will be 11.5:1. so is that enough??? and if anyone know is ther much diffrence between skunk2 cams and brian crower ones?? thanks
ok well i know for a fact that the compression will bump up just a tad with stage 2 cams....your compression with those pistons i belive should be 10.2:1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW_98gsr »</TD></TR><TR><TD CLASS="quote">ok well i know for a fact that the compression will bump up just a tad with stage 2 cams....your compression with those pistons i belive should be 10.2:1</TD></TR></TABLE>
what?? ok im not even going to comment on this
That made no sense at all. Besides since when do cams "Bump" up compression.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcMONSTER »</TD></TR><TR><TD CLASS="quote">
That made no sense at all. Besides since when do cams "Bump" up compression.</TD></TR></TABLE>
dont pr4 pistons CR at 10.2:1?
and i thought the cams would bump up the CR just a little bit, like .2 or something...isnt this true?
I think he's refering to dynamic compression rather than static compression. Am I right vit? However, dynamic compression requires a lot more information to calculate correctly. For example ramp angle, duration, overlap, etc.... There is a formula on the team-integra site and a way of calculating dynamic compression but it's pretty deep. And yes, the bigger the cam the lower your dynamic compression will be because of duration and overlap. Even though your static compression stays the same.
But 11.5 static compression should be enough for stage 2. I have 11.0 static compression and I run Skunk 2 Stage 2's and make decent power. You should hear the vtec roar.
Good luck.
Good luck.
Got Milk
15
Nov 13, 2005 10:05 AM
