Type-S ECU
Old Sep 15, 2006 | 11:27 AM
Revi's Avatar
Default Type-S ECU
I ordered a Type-S motor to throw in my 98 SH and it brings the ECU as well. Do i have to use this ECU or could i use the one already in my car? Will in conflic with the immobolizer(sp)?
Old Sep 15, 2006 | 12:01 PM
K-Spec's Avatar
Default Re: Type-S ECU (Revi-Ra)
you could prbly use your stock sh ecu since they're both ATTS. For the immobilizer issue, that shouldn't be a problem since it's not in the ECU but a separate unit.
Old Sep 15, 2006 | 12:07 PM
Chuckles99SH's Avatar
Default Re: Type-S ECU (khalal538)
Yea but the type-s ecu has the proper tune for 11.1 comp ratio and more agressive cams.. i'm not sure if this would make a difference. The type-s ecu probably will also have a govener at 120 or something like that from what ive read thats the JDM ecu cut out.
Old Sep 15, 2006 | 12:14 PM
K-Spec's Avatar
Default Re: Type-S ECU (Chuckles99SH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chuckles99SH &raquo;</TD></TR><TR><TD CLASS="quote">Yea but the type-s ecu has the proper tune for 11.1 comp ratio and more agressive cams.. i'm not sure if this would make a difference. The type-s ecu probably will also have a govener at 120 or something like that from what ive read thats the JDM ecu cut out. </TD></TR></TABLE>
ecu should advance or retard the timing to comp for the compression and more aggressive cams. i ran my base ecu p5m with my euro-r setup before i got a hondata tuned p28 ecu and it ran fine. to the OP, i'd say it's ok to run the stock ecu with the type-s engine.
Old Sep 15, 2006 | 12:26 PM
vinuneuro's Avatar
If you got a type-s ecu with the swap, use it...it can't cost that much for Honda to re-code it for you..
Old Sep 15, 2006 | 12:36 PM
Revi's Avatar
Default Re: Type-S ECU (vinuneuro)
Yeah my concern was the 11:1 comp and cams. I dont know if the computer will tune itself out like khalal said. Can anyone very this? As far as the limiter at 120 goes, i dont plan on doing that in the public roads and i sure wont be hitting that as my 1/4 speed so i wont worry about that for now. Unless i decide to run from the cops anytime soon
Old Sep 15, 2006 | 12:38 PM
K-Spec's Avatar
type-s cams aren't that aggressive. so you think everytime people replace their cams with like s2 or crowers they replace their ecu? i highly doubt that. also, no point in putting those in if your car isn't tuned.
Old Sep 15, 2006 | 12:53 PM
Revi-Ra are you in state that hugs trees and keys humvees? If so you might want to keep your stock ecu and rig the type-s engine with all your stock emmissions gear to try to be legit. Keep us updated cause i'm thinking about doing this swap myself, and i would like to know if you are able to retain stock emmissions equipment for smog testing. And yea i forgot the ecu would componsate for comp/cams.
Modified by Chuckles99SH at 2:33 PM 9/15/2006
Old Sep 15, 2006 | 02:14 PM
K-Spec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chuckles99SH &raquo;</TD></TR><TR><TD CLASS="quote">Revi-Ra are you in state that hugs trees and keys humvees? If so you might want to keep your stock ecu and rig the type-s engine with all your stock emmissions gear to try to be legit. Keep us updated cause i'm thinking about doing this swap myself, and i would like to know if you are able to retain stock emmissions equipment for smog testing. And yea i forgot the ecu would componsate for comp/cams.
Modified by Chuckles99SH at 2:33 PM 9/15/2006</TD></TR></TABLE>
he won't pass emissions with a type-s engine...esp if it isn't tuned for emissions.
Old Sep 15, 2006 | 02:56 PM
vinuneuro's Avatar
everytime someone gets new cams, pistons,etc they tune to compensate. That is exactly what he is doing by using the type-s ecu...using the proper tune for the engine. The sh ecu will use the right amount of fuel for a h22a4 engine, when it detects the lean condition/knock in the type-s engine due to lack of fuel, it isn't going to add ridic amounts of fuel, it's going to pull timing.
Old Sep 15, 2006 | 04:35 PM
Revi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">everytime someone gets new cams, pistons,etc they tune to compensate. That is exactly what he is doing by using the type-s ecu...using the proper tune for the engine. The sh ecu will use the right amount of fuel for a h22a4 engine, when it detects the lean condition/knock in the type-s engine due to lack of fuel, it isn't going to add ridic amounts of fuel, it's going to pull timing.</TD></TR></TABLE>
So you are saying is use the Type-S ECU, which is what i was thinking. It only makes since since the computer should already be set up for the higher compression and cams. I live in Florida so no emmisions here. So with the Type-S ECU i will be able to get rid of the EGR and other emmision crap with no prob? I dont know if the Type-S brings all that anyways, guess ill finda out. I would love to get rid of all the emmision stuff if i could. Ill keep everyone updated on this swap.
imzjustplayin
Apr 12, 2008 03:56 AM
SOHC_MShue
Oct 14, 2002 11:22 AM
