maintenance indicator
Old Sep 15, 2006 | 10:58 AM
maxflame's Avatar
Default maintenance indicator
For the longest time my little "requires maintenance" color indicator was green but it just recently turned yellow, but my car runs fine. Does it mean there could be a minor problem with the car or is it because of the fact I'm about to hit 170k miles on it?
Old Sep 15, 2006 | 12:28 PM
Intense3.2's Avatar
Default Re: maintenance indicator (maxflame)
The indicator just turns colors after a certain amount of miles, works in conjunction with your odometer, next is red. You can reset it by pushing your key into the little slot next to it on the cluster. It will go back to green, no need to worry.
Old Sep 15, 2006 | 01:31 PM
BlUAc's Avatar
Default Re: maintenance indicator (Intense2.2 _Y.T.S._)
na it just means that its time for a oil change or tune up or something like that
Old Sep 18, 2006 | 07:12 PM
gianinline's Avatar
check the owner's manual to see what "should" be replaced at this time of your mileage.
Old Aug 15, 2007 | 11:49 AM
H22_aCCoRd_07's Avatar
Default Re: (gianinline)
thanks for the info
Old Aug 15, 2007 | 01:08 PM
lunarone's Avatar
i'm pretty sure it turns yellow at 5k miles, then red at 7.5k miles, after a reset.
Old Sep 5, 2009 | 08:47 PM
AJ_ashu9uf's Avatar
oh ... cool! thanks!
Old Sep 6, 2009 | 07:09 PM
nus_dogg's Avatar
Mine is always wayy off. It never turns correctly by the time I'm due for an oil change.
Old Sep 10, 2009 | 12:12 PM
majalcar65's Avatar
Based from experience w/ my 92 Accord, the maintenance indicator turns yellow as a reminder that I need to change my oil soon. It then turn red within a hundred miles. The indicator comes sooner when I used non-synthetic oil and it never comes on when I used synthetic. I changed the oil between 4-5000K anyway instead of waiting for the indicator to turn yellow and red. I wonder if there is a system monitoring the condition of the oil that relay info to the indicator.
Old Sep 10, 2009 | 09:41 PM
bseriescrxsi's Avatar
no theres not....it merely runs off miles traveled
omarisramo
Mar 28, 2008 07:35 AM
lalaine17
Apr 13, 2006 01:51 PM
Iamcuddles
Dec 10, 2005 08:45 AM
Ideal
Jan 11, 2003 05:29 PM
