Comptech Rear Sway Bar with Lower Tie Bar
Old Apr 29, 2002 | 09:14 PM
Dodger2940's Avatar
Default Comptech Rear Sway Bar with Lower Tie Bar
I read on the Computech site that this combo does not fit with some aftermarket exhaust is this true? Does anyone have there sway bar? If you do what exhaust are you running? I am thinking of getting this sway bar combo and purchasing a Apexi World Sport exhaust does anyone know if they will fit good together? Any info will be helpful
Old Apr 29, 2002 | 09:36 PM
EkREV's Avatar
New User
Default Re: Comptech Rear Sway Bar with Lower Tie Bar (Dodger2940)
the piping on the axle-back muffler on some aftermarket exhaust sytems may hit the comptech swaybar. if it does, have the piping fabricated so that it won't hit anymore. sorry, but i don't know if the apex WS will have fitment problems w/ the comptech swaybar.
Old Apr 30, 2002 | 11:24 AM
Dodger2940's Avatar
Default Re: Comptech Rear Sway Bar with Lower Tie Bar (EkREV)
Thanks for the info. Does anyone else have any input?
Old Apr 30, 2002 | 11:29 AM
ToneyTigre's Avatar
New User
i had a apexi WS exhaust and comptech sway. no problem with the fitment at all. go for it. u have nothing to worry about. the comptech sway bar does not hinder the exhaust system at all.
tho, i must say, the apexi WS sometimes has fitment problems of itself. many complain that the piping rubs against the gas tank making a loud rumbling noise around 3000rpm. i had that problem. also the resonator is really big. if your car is lowered like mine, about 1.8inches, it scraps over speedbumps and driveways. if i had to do it all over again, i'd just get the WS muffler section and have the local muffler shop fabricate a b-pipe.
BTW, i fixed the rubbing problem by goign to the muffler shop, they heated the piping and moved it a lil. cost me $20. but they weren't able to solve the big resonator problem it scraped like a bitch. my car is back to stock now. got too many tickets for it. now in Nor CA, its not a fix-it anymore. keep in mind, ther's no CARB number on the WS.
[Modified by ToneyTigre, 12:41 PM 4/30/2002]
Old Apr 30, 2002 | 12:10 PM
Dodger2940's Avatar
Default Re: Comptech Rear Sway Bar with Lower Tie Bar (ToneyTigre)
Ah man is there another exhaust the you recomend? That is not loud and that is quiet? Should I just go the ES/Magna Flow local muffler shop route or its there one out there that works the same as the WS?
Old Apr 30, 2002 | 12:12 PM
AB16A2T's Avatar
I have the rear Comptech Sway Bar and the Comptech Exhaust system too, no problems here. The exhaust system is pretty damn quiet, unless you are on WOT.
Old Apr 30, 2002 | 12:18 PM
Dodger2940's Avatar
Default Re: Comptech Rear Sway Bar with Lower Tie Bar (Ares81883)
How much the exhaust run you? Thats what I want a system that is quiet untill it is @ WOT
Old Apr 30, 2002 | 12:38 PM
AB16A2T's Avatar
Comptech Exhaust Power Pro - S/S Catback $575.95. It works great, sounds great. I have no complaints.
Old Apr 30, 2002 | 02:42 PM
RacerXI's Avatar
I have the comptech sway bar w/ a tanabe racing medallion w/ no problems.
Dr0d23
Acura TSX
May 26, 2008 10:29 PM
99blackLS
Jun 15, 2006 06:58 PM
Chuck Dean
Suspension & Brakes
May 28, 2006 11:12 PM
ANDREW D
Mar 17, 2005 05:30 AM
civ98
Mar 27, 2004 02:14 PM
