Budget LS/Vtec (Daily driven/ street) CAM question
Old Sep 15, 2006 | 09:17 AM
BeeEK9R's Avatar
Default Budget LS/Vtec (Daily driven/ street) CAM question
im building Ls vtec. i have a question on the cam i should use on a b16a2 head with type R v-train. i know type r cam is the obvious chose but is there other cam that would also work with type r v-train.
Bottom end set up
B18b1 block
crank and rod balanced
ITR piston STD
ITR oil pump and water pump
gsr gridle
acl bearing
ARP headstud and rod bolt
golden eagle lsvtec kit
also should I put on a block gaurd (will it help)
Im lookin for atleast 180whp also want it to be reliable
Old Sep 15, 2006 | 09:30 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: Budget LS/Vtec (Daily driven/ street) CAM question (BeeEK9R)
any stage 1 cam should be fine
Old Sep 15, 2006 | 09:33 AM
BeeEK9R's Avatar
thank u any brand u recommend
Old Sep 15, 2006 | 09:42 AM
cute little bastard
Default Re: (BeeEK9R)
I personally like Skunk2s
I think Blox are the same specs for a little cheaper.
A lot of people will probably say Buddy Club spec 3+ but I'm not a fan of them.
Old Sep 15, 2006 | 01:45 PM
jamessh1's Avatar
Default Re: (SkoundrelUSA)
I made 196 whp with sk2 stage 1s in my car (lsvtec with jdm type r pistons) using the oem type r valve train, that would be my recommendation based on personal experience. although as stated above the bc3+s are another good choice.
Old Sep 15, 2006 | 02:08 PM
BeeEK9R's Avatar
nice is there ways to use a higher stage cam by changing lil part from the type r v-train. like adding lil stuff like titanium retainer or changing inner spring or outter also im thinkin of buying intake manifold wat good, i heard Blox makes great IM
Old Sep 15, 2006 | 02:25 PM
DonF's Avatar
ak your engine buillder/ tuner wa lil tings you can do make tings better, outter and inner springs wood be good then a 2 cam, along with a BLOX mannyfold.
Old Sep 15, 2006 | 02:31 PM
97L-esVeeTeg's Avatar
Default Re: (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">ak your engine buillder/ tuner wa lil tings you can do make tings better, outter and inner springs wood be good then a 2 cam, along with a BLOX mannyfold.</TD></TR></TABLE>
lol
Old Sep 15, 2006 | 03:20 PM
EH-3's Avatar
Default Re: (DonF)
what language is that?
purple_civic94
Aug 25, 2012 02:19 PM
projectef
Sep 1, 2007 09:49 AM
fiftee_su
Jul 23, 2006 12:44 PM
RATED EG
Nov 13, 2005 11:30 PM
