DO YOU THINK THIS WOULD WORK?
Old Sep 15, 2006 | 09:12 AM
IIDIEIV619's Avatar
Default DO YOU THINK THIS WOULD WORK?
I JUST CAME ACROSS A B16A2 FROM 99-00 CIVIC SI. I OWN A 86 CRX SI. YOU KNOW WHERE IM GOING WITH THIS LET ME KNOW WHAT YOU THINK OR ANY SUGGESTIONS YOU HAVE ON DOING THIS SWAP? FILL ME IN ON ANY OPINIONS..THANKS
Old Sep 15, 2006 | 10:28 AM
Fezzie's Avatar
Default Re: DO YOU THINK THIS WOULD WORK? (IIDIEIV619)
it will work you will have to get a hydrolic to cable conversion but on the new project.
Old Sep 15, 2006 | 10:36 AM
EL Vap133's Avatar
Default Re: DO YOU THINK THIS WOULD WORK? (Fezzie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fezzie &raquo;</TD></TR><TR><TD CLASS="quote">it will work you will have to get a hydrolic to cable conversion but on the new project.</TD></TR></TABLE>
You need a LOT more than that.
Old Sep 15, 2006 | 10:41 AM
Jschnatter's Avatar
Default Re: DO YOU THINK THIS WOULD WORK? (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote"> You need a LOT more than that. </TD></TR></TABLE>
YES, but it's definatly doable... I would get an obd1 b18 if i were you... having no ***** sux! or at least get obd1 b16.
but it's ur car... If you decide to do it, good luck.
Old Sep 15, 2006 | 11:36 AM
98lude-t's Avatar
Default Re: DO YOU THINK THIS WOULD WORK? (Jschnatter)
it work i have done it
you need hasport mounts about 450 and axles. half shafts outa a 88 teg and knuckles brakes . ihave a set of axles somwhere i think. you need a obd0to obd1 conversion and it should be good. if you have a hydro trans then a hasport converter
Old Sep 15, 2006 | 12:56 PM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
http://www.redpepperracing.com
Read the FAQ before asking questions.
Nssj_408sj
Jun 14, 2008 08:58 AM
Patman
Honda Motorcycles
May 3, 2008 07:56 AM
Aggressive Racing
Honda Civic (2006 - 2015)
Jun 18, 2007 12:46 PM
dohcvtecsol
Oct 31, 2003 07:10 AM
speedracer33
28
Jul 23, 2003 06:28 PM
