Is it my main fuel relay causing problems? 95-gsr
Old Sep 15, 2006 | 08:59 AM
Rob Dizzle's Avatar
Default Is it my main fuel relay causing problems? 95-gsr
When the ambient air temp is hot my car doesnt want to start after driving it. So after searching around for the last two days, it seems like 90% of the problems are related to a busted main fuel relay.
It was around 70* yesterday and didnt have any problems all day and drove it kinda hard before I got into work and it would start right back up after I parked it for a minute. Then later that night I drove home and parked it for an hour then I had to move it. I started it up again after 90 seconds later and it started ok but was really rough until I put a load on the engine. If I didnt give it gas and drive it around it would sputter and probably die when leaving it at idle.
I put in new NGK plugs and OEM plug wires last week so that isnt it.
This morning I took out the relay and all the solders look fine. Is it possible a solder joint below the surface is bad?
Only other thing I can think of is the ignitor in the distributor. But it seems my problem seems to be more ambient related but not engine temp.
edit: I bought a new main relay and it didnt solve the problem. Car still starts rough after it been driven. So I might buy a new dizzy and hope it solves it.
Modified by Rob Dizzle at 1:11 PM 9/15/2006
Old Sep 15, 2006 | 10:31 AM
BLKGSR24's Avatar
Just listen for the relay to click before you start your car. That's the easiest way to determine if your relay is at fault.
Old Sep 15, 2006 | 11:25 AM
Rob Dizzle's Avatar
Default Re: (BLKGSR24)
I bought a new relay but that didnt fix the issue. car was sitting in the sun when I went to the dealer, car wouldnt start. I swapped relays and same issue, it wont start.
I waited about 30 mins then tried to start. It would only start when I put the gas all the way down and it started really rough then drove fine after that.
Old Sep 15, 2006 | 11:37 AM
JasonST's Avatar
Default Re: (Rob Dizzle)
Sounds like an ignition problem if it's running rough. An easy way to tell if it's the relay or pump just listen for a hissing sound coming from ur engine bay, that's the fuel pump pressurizing the fuel line, if u don't hear the hiss then it's probly some problem with ur pump since u already replaced ur main relay and had no luck. Check ur spark plugs when ur car's running rough see if they're running rich or lean.
Old Sep 15, 2006 | 12:17 PM
Rob Dizzle's Avatar
Default Re: (JasonST)
yah i just put new plugs in so i will take them out and see what color they are.
DeeJaaY209
12
Sep 26, 2013 12:02 PM
TheToaster
Oct 18, 2012 07:41 AM
RuskeR
Nov 15, 2006 08:30 AM
Rob Dizzle
Sep 15, 2006 06:55 PM
ZedEx
Jul 1, 2005 01:41 PM
