Help me fix my hood!
Old Sep 14, 2006 | 09:48 PM
jdmazm's Avatar
Default Help me fix my hood!
I don't know wtf the problem is here. I've been trying to adjust this hood since forever, I've tried spacers to even the gap. Tried to sit on it. Nothing, anyone got any freakin idea on how to fix this? It looks crooked but can't seem to get it adjusted.
left side gap
under hood.
Old Sep 14, 2006 | 11:29 PM
didyouhearthat's Avatar
Default Re: Help me fix my hood! (jdmazm)
If you look at the headlight and corner light, there is also a gap. Doesn't look like the hood is the problem. Any front end damage in the past?
Push the headlight upward, and unscrew the fender and pull it away from the front of the car and then tighten it down.
Old Sep 15, 2006 | 12:04 PM
jdmazm's Avatar
Default Re: Help me fix my hood! (didyouhearthat)
hmmm, so pull the headlight out and try to straighten the frame?
Old Sep 15, 2006 | 12:13 PM
'90crxSI's Avatar
I think your hood is fine....your headlight looks like it is sitting lower than it should, also your bumper is lower on the drivers side too!...Thats easy to adjust...once you figure out how to adjust the light, remove the bumper turn signals, and theres two bolts behind it. loosen those and that will help you realign the bumper. From your pic, your hood appears to be lined up with the side marker and fender. Good luck!
Old Sep 15, 2006 | 12:37 PM
boostedSI90hatch's Avatar
Banned
Default Re: Help me fix my hood! ('90crxSI)
my radiator core was bent up one time and it made my hood alinment look like **** i bent it back down and wala its all better( it got bent from a jack sliding off the crossmember into the support)
Old Sep 15, 2006 | 01:52 PM
1_slow_crx's Avatar
Default Re: Help me fix my hood! (boostedSI90hatch)
i've seen that car before. wat a pos!!!!!
Old Sep 15, 2006 | 01:54 PM
jdmazm's Avatar
Default Re: Help me fix my hood! (1_slow_crx)
lol, gimme my seats back!!
I'll post up when i get this fixed, gonna get on it right now
Old Sep 15, 2006 | 02:06 PM
1_slow_crx's Avatar
bahaha........... come install my coil-overs!
Old Sep 20, 2006 | 07:20 PM
jdmazm's Avatar
i fixed it, you guys who said it was the headlight, you were right. I raised the bumper support and now the gap is tighter than a virgin.
integraa972
11
Aug 29, 2006 01:18 PM
LagunaSecaEG
Jul 20, 2006 12:02 PM
EgRedSi
15
Nov 15, 2004 09:50 AM
eg686
Jan 8, 2004 10:53 AM
bad93ex
Nov 23, 2002 05:55 AM
