speedo stopped working and then i got a CEL
Old Sep 14, 2006 | 09:33 PM
superstock2's Avatar
Default speedo stopped working and then i got a CEL
so i was driving, all the sudden speedo dies and like 10 minutes later the check engine comes on... whats the deall? i know the speedo calbe is probably unhooked, but would that cause a Check engine light to come on?
Old Sep 14, 2006 | 11:46 PM
Fezzie's Avatar
Default Re: speedo stopped working and then i got a CEL (superstock2)
check the vss on the tranny the plug might have came off or something
Old Sep 14, 2006 | 11:49 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superstock2 &raquo;</TD></TR><TR><TD CLASS="quote">so i was driving, all the sudden speedo dies and like 10 minutes later the check engine comes on... whats the deall? i know the speedo calbe is probably unhooked, but would that cause a Check engine light to come on?
Lol, mine popped out after the tranny swap I did and i threw a CEL. I just stuck it back in and haven't had a problem since, lol.
Old Sep 15, 2006 | 06:23 AM
Loserkidwac's Avatar
Default Re: speedo stopped working and then i got a CEL (Tippyman)
VSS is like code 7 or something so yes if you speedo dosen't work you will get a CEL
Old Sep 15, 2006 | 06:40 AM
gospeedgo1's Avatar
Default Re: speedo stopped working and then i got a CEL (Loserkidwac)
vss/ speed sensor should be code 17 on obd 0. my light just came on too. check the back of the gauge cluster to make sure its in tight. then check to see if its in securely (held in with a metal clip) to the tranny speedo hole. you could also pull out the speedo cable and check its length to make sure its not broken. there is an article on this in FAQs i believe
Old Sep 15, 2006 | 06:47 AM
Default Re: speedo stopped working and then i got a CEL (gospeedgo1)
Code 7...17 eh i was close
Old Sep 15, 2006 | 01:44 PM
sweet thanks guys!
95civicproblems
11
Jul 23, 2011 06:23 PM
steelrainwarrior
14
Nov 5, 2006 05:41 PM
egturbolsvtec
Mar 15, 2006 03:20 PM
idriveadelsol7
Aug 29, 2005 09:29 PM
wm5holla
Mar 15, 2003 12:40 PM
