type-s head
Old Sep 14, 2006 | 09:31 PM
cam3ron88's Avatar
Default type-s head
could i put a type-s head on my k20a3? and i f so how much would it cost?
Old Sep 14, 2006 | 10:09 PM
hatch96y7's Avatar
Default Re: type-s head (cam3ron88)
yes u could but there is something else to do i cant remeber other then just swapping over the head
Old Sep 15, 2006 | 12:02 PM
VTECth1s's Avatar
i was just thinkin of that same questions last night....would anyone care to elaborate on this...curious myself on the steps..etc
Old Sep 15, 2006 | 03:58 PM
Reborn's Avatar
Reborn_
that something else you need is kpro (or possibly a prb ecu, not sure if that is sufficient)
the general consensus is that you may as well just swap the whole motor instead of doing the head swap
Old Sep 15, 2006 | 05:01 PM
woolfgang's Avatar
I think about it my self to do it ,
here what you need
k20 a2 or z1 head
intake manifold
throthle body
ecu ( need the go to honda dealer to set the key immobilizer )
and time cause you need to take the engine off of the car to loose the timming chain thats mean not shure but pretty confiant that you have to empty the ac but some part are not the same in the block k20a3 and are highly recommend to add to be swap into a k20a2 z1 . Like the crankshaft not ballance enought to spin at 8700 rpm (hondata reflash ) piston does not have oil squirter to cool down those oil filter is not water coolded . if you dont plan to change piston to get from 9.8 to 10.5 cp ratio i think your k20a3 will handle it nicelly but dont rev to hard on a unbalanced crank it make a big mess when it broke !!!
I do not confirm everything i say thats was the answers i get for the same question i post on montrealracing forum !!! take it or leave it !!!
meckas792
Aug 13, 2009 07:18 AM
ctrep3
May 24, 2005 08:15 PM
as i lay dying
Apr 21, 2004 05:48 PM
as i lay dying
Apr 20, 2004 08:45 PM
HaTcH_BmX
11
Nov 4, 2003 04:08 PM
