Changing Fog Light Bulb ? How To On DA?
Old Sep 14, 2006 | 08:22 PM
Extreez's Avatar
Default Changing Fog Light Bulb ? How To On DA?
How do i change the fog light bulb on a DA i notice theres a rubber blocking and way too tight to work wit it, im guessing take the headlight unit out, doing this is it only the 3 bolts on top and the screw for the corners thats holding my headlight or are there more on the bottom, also once taken out how does this work does the rubber cover come off to change bulb ?
Old Sep 15, 2006 | 06:04 AM
Extreez's Avatar
Default Re: Changing Fog Light Bulb ? How To On DA? (Extreez)
bump
Old Sep 15, 2006 | 06:11 AM
mr.beeks's Avatar
on the fog light you will notice a small size 8MM nut remove and pull from that side and the fog light will come out. b carefull with not breaking the small pegs on opposite side.
Old Sep 15, 2006 | 07:57 AM
tegG2's Avatar
http://www.team-integra.net/se...D=289
Hope this helps.
JayVIP
Aug 16, 2014 10:37 AM
sz9182
Oct 13, 2009 05:43 PM
animated_life
Dec 27, 2003 12:03 PM
4gen
Sep 8, 2003 11:42 PM
