wiring crx b18a1 swap
search on this forum for "mpfi swap" & "obd1 conversion"
you must use the crx harness and modify it for the 93 teg electronics. swap the teg's distributor & injector plugs over to it.
then the ecm and everything will plug right in and work
most of the sensors would plug in, yes. the fan switch moves from the back of the block on the crx to the thermostat housing on the teg. you need to swap that plug as well.
use the teg ecm (ecu in honda world)
it's a REALLY good idea to start with a harness from the same year / trim / model vehicle and go from there
what year is the engine?a 1990 or 1991 Integra changeover would be the easiest for you guys. otherwise, go here:
http://www.rywire.com
They sell an OBD-0 to OBD-1 conversion harness, along with everything else to make the swap real easy for you.
newtype_racing
Dec 15, 2008 03:57 PM
fracas
Feb 23, 2008 09:38 AM
