radiator question quick and easy
Old Sep 14, 2006 | 06:50 PM
bboy_mikey's Avatar
Default radiator question quick and easy
i just wanna know if an integra ls coolant tube will fit into a crx radiator
Old Sep 14, 2006 | 07:35 PM
mahatma's Avatar
Default Re: radiator question quick and easy (bboy_mikey)
i have an integra upper and civic lower on my stock radiator. had to cut the integra hose and clamp it well in order to make it fit though. (LS motor in civic)
Old Sep 14, 2006 | 07:42 PM
bboy_mikey's Avatar
well i didnt cut anything cuz my integra coolant hose goes right into my crx radiator insert and i can pretty much stick my finger in the tube while its connect unless i get a hoseclamp to tighten it down but thats just bad for the tube im told i just wanan find out befor goign out and buying a new coolant tube the radiator i got is off ebay btw
Old Sep 14, 2006 | 07:52 PM
mahatma's Avatar
Default Re: (bboy_mikey)
well you can use an integra radiator if you want, but it's easier to modify the radiator hose you have. it won't hurt to put a squeeze on the hose, just make sure it's not kinked when you're done.
but BE CAREFUL not to crack the plastic hose neck!!
Old Sep 14, 2006 | 08:22 PM
bboy_mikey's Avatar
what whould happen if i crack the hose neck? is that whats connected to my filler tank??
Old Sep 14, 2006 | 08:27 PM
mahatma's Avatar
the plastic part of the radiator, where the upper hose connects, is prone to cracking under moderate clamp pressure. just be careful with it. if it cracks you'll lose coolant and overheat.....not good lol.
Old Sep 15, 2006 | 11:34 AM
bboy_mikey's Avatar
Default Re: (mahatma)
ohh thats what happened to my last radaitor so i got a new one on ebay thanks for the info
Old Sep 15, 2006 | 11:56 AM
Loserkidwac's Avatar
You can get a rd hose for a car that had a civic rad and a B series motor, like the 93-97 Del Sol SIR or the 99-00 Civic Si...they should have a small end for the rad and a larger end for the B motor
Old Sep 17, 2006 | 03:36 PM
bboy_mikey's Avatar
Default Re: (Loserkidwac)
sounds good i wil go for that thanks
Jesseking24
Jun 20, 2010 01:13 PM
DocSean
Aug 17, 2005 10:45 AM
B18Redline
Dec 2, 2004 09:35 AM
lucasbkellner
10
Nov 15, 2004 04:13 PM
