buddy club iv tried search
Old Sep 14, 2006 | 06:35 PM
tempsohc's Avatar
Default buddy club iv tried search
Well heres my setup.
USDM B18c1 99 motor
Stock bore and pistons
ARP rod bolts
GSR Portflow cylinder head milled .004(shaved flat)
Skunk2 runners ported manifold(matched)
Bullfrog 65/62mm Throttlebody
BuddyClub head gasket
Skunk2 valvesprings & retainers(pro series)
Skunk2 high comp valves
DC ITR 4-1 Race header(2.5 collector)
Clutchmasters stg 3 clutch
Exedy flywheel 8.5lbs-9.5lbs??(forgot)
Hondata s200
Was wondering how well these cams would do in my car...i had skunk2 stg2's previously but someone offered me enough money to buy the buddyclubs brand new..so i figure i'd tried something new...any dynos or comments you could send my way with something similiar to my setup? Thanks allot guys...read my sig to see my best time with the sk2 2's
Old Sep 14, 2006 | 08:44 PM
tempsohc's Avatar
bump
Old Sep 14, 2006 | 08:47 PM
super_nguyen's Avatar
Default Re: (tempsohc)
IMHO, your stock compression probably won't make the best use of the cams.
Old Sep 14, 2006 | 08:50 PM
Ruben19's Avatar
need higher compression to run this cams.
10.2 is no much
Old Sep 14, 2006 | 09:12 PM
tempsohc's Avatar
i calculated it out to be some where between 10.7-11.0...cause stock is 10.0 the valves supposedly add .4 and the head gasket add .3-.4. Any more opinions..will they make power or will they just be crap? I mean full potential is one thing and making power is another.
Old Sep 14, 2006 | 10:34 PM
oldskool teggy's Avatar
same peak power as skunk stg2
Old Sep 15, 2006 | 04:26 PM
tempsohc's Avatar
i thought the buddyclubs had more lift and allot more duration than the sk2 2's??? anymore comments? thanks allot for the input
Old Sep 15, 2006 | 06:23 PM
esohsee's Avatar
11.5 comp. would be the least you would need to run the bc4's. the s2s2 are a very good cam you should just stick w/ those.
Old Sep 16, 2006 | 03:41 PM
tempsohc's Avatar
i already sold them???
Old Sep 16, 2006 | 03:58 PM
DonF's Avatar
BC4's and Sk stage2's have the same VTEC lobes. The primary's are different. The BC4 EX has a Toda C primary, and not sure who they coppied for the IN primary. You might gain a little before VTEC.
Old Sep 16, 2006 | 08:53 PM
tempsohc's Avatar
thanks thats the kinda info i was looking for..thanks...don f...very informative...i'll keep you posted and maybe post a review and a dyno chart if i can get an appointment here in hawaii...thanks
cmross13
53
Jun 11, 2012 08:02 AM
Wayeng
Feb 21, 2011 05:05 AM
ninja95gsr
Sep 14, 2010 12:54 AM
1993gsrcivic
23
Apr 28, 2008 03:07 PM
94IntegraLs04
13
May 31, 2006 06:57 PM
