My Oxygen Sensor & Vtec
Old Sep 14, 2006 | 05:51 PM
fast_honda's Avatar
Default My Oxygen Sensor & Vtec
I have a jdm h22a. My timing belt broke, I bent some valves. Honda put on new timing belt, water pump, tensioner and valves. My car doesn't quite drive the same, it's very sluggish at around 2-3k rpms AND what's really weird is that VTEC hits too early now. It hits at 5,000rpm, instead of 5,200. It's throwing a CEL #1, which is the oxygen sensor (primary) correct? Do these symptoms describe a faulty oxygen sensor?
Old Sep 14, 2006 | 06:45 PM
fast_honda's Avatar
Default Re: My Oxygen Sensor & Vtec (fast_honda)
Ok, can VTEC be affected like this if my o2 sensor is bad? My ECU is obviously trying to compensate for something.
Modified by fast_honda at 8:49 PM 9/14/2006
Old Sep 15, 2006 | 01:23 AM
TheWalrus's Avatar
yeah an oxygen sensor is the most common reason for an engine to stumble randomly...and since youre throwing that code, take it back to honda. its easy to test and shouldnt cost that much (wait nevermind, its a honda dealer)
Old Sep 16, 2006 | 02:18 PM
fast_honda's Avatar
Default Re: (weenie)
It's just weird that VTEC is engaging earlier than normal. The wiring to the silenoid looks right, but the mechanic did say he tends to set the valves on the looser side.
Terabass
Jan 21, 2020 06:07 PM
jachrist
Oct 1, 2009 12:50 PM
h22bb1
Apr 5, 2008 08:13 AM
miguel_aka_timon
Nov 14, 2006 11:50 AM
