vss removal, help!
Old Sep 14, 2006 | 05:12 PM
philkehn's Avatar
Default vss removal, help!
well i was looking at changes off my electric vss of my tranny to a cable so i can actually use my speedometer, now the problem. I found a cable vss at the junk yard i went to take it off and i just couldnt figure out to get it off, so how do i get that off, visa versa with the electric vss how do i get that off.. are there bolts? if so where...
Also I can take a cable vss from a ls and it will work ok with my b16a electric tranny?
Old Sep 14, 2006 | 05:31 PM
civiconfire's Avatar
Default Re: vss removal, help! (philkehn)
for the cable one...pull the boot up and you should feel a clip on the motor side... you have to take that out...it should pretty much fall out.... i dont know about the electronic one
Old Sep 14, 2006 | 05:33 PM
philkehn's Avatar
are you talking about the cable, cuz im talking about the thing that you plug the cable into
Old Sep 14, 2006 | 05:34 PM
jchrm80's Avatar
Default Re: vss removal, help! (civiconfire)
the electric vss has one bolt holding it in. I am currently doing the exact same thing you are doing but I bought a used cable vss. I cannot get mine to work.
Old Sep 14, 2006 | 05:37 PM
philkehn's Avatar
maybe they are not compadable <-- is that spelled right --- ??? Anyone have any idea, or has anyone successfully did this? Also are there any other crx bolt up clusters that are electric driven?
Old Sep 14, 2006 | 10:08 PM
philkehn's Avatar
Old Sep 14, 2006 | 10:29 PM
civickiller's Avatar
Default Re: (philkehn)
you can interchange them, there should only be one bolt holding it on. just twist and pull and it should work itself loose. just hard because its been in there for so long.
oh and too let you know in case you dont believe me. i am running a hydro tranny, whihc is a electronic vss, with a cable vss.
Old Sep 15, 2006 | 08:47 AM
philkehn's Avatar
good deal, I was just looking for someone who has successfully done it So its pretty much just plug n play, my ecu does how ever expect a electric vss, so i will still have a check engine light? if so how would i take care of the cel or is there no way to, if not its ok
Old Sep 15, 2006 | 09:49 AM
nappyroots827's Avatar
there is a wire going from the ecu to the cluster, so when the speedometer works, it will send a signal to the ecu so your light should go out...and the cable sensor will fit in your tranny, but they are a pain in the *** to get out, took me about 3 days of drilling, hammering, and torching to get mine out which mind you finally came out in about 30 pieces....the electric sensors will usually pull right out tho...both sensors have a 10mm bolt holding it in, just take that out and wiggle it lose and pull it out.
Old Sep 15, 2006 | 10:22 AM
philkehn's Avatar
good deal, I have to get my out at the junk yard so thats gonna be all hand tools getting it out, looks like ima have some fun for the love of my rex
Old Sep 15, 2006 | 01:37 PM
in all honesty, if you can't get the cable driven vss out right away, just buy one from somebody, cuz in your most likely gonna end up breaking the tab off
Old Sep 15, 2006 | 01:59 PM
NikoZai's Avatar
Default Re: (nappyroots827)
Haven't done this in a while but I do believe THERE'S A C-CLIP HOLDING IT ON!!!!!!
Pry off the C-Clip just like you would on the window regulator to get the door panel off.
Old Sep 15, 2006 | 06:34 PM
philkehn's Avatar
I got a cable one, works but i still have a cel
Old Sep 16, 2006 | 02:03 PM
philkehn's Avatar
bump on how to get rid of my CEL if I even can?
turbo-crx
Oct 24, 2008 06:44 PM
philkehn
Nov 19, 2006 10:08 AM
IhEARTjDM2
Oct 24, 2005 02:39 PM
jcrou
Dec 17, 2004 08:56 AM
drjondurst
Mar 29, 2003 06:34 PM
