toda timing belt and cam gears question
Old Sep 14, 2006 | 05:00 PM
blacK_Dc4's Avatar
Default toda timing belt and cam gears question
hey i have a question .. i bought a set of toda cam gears for a gsr and the shop sent the one for a b16a .. the instruction papers said that all the b16a and the gsr b18c uses the same cam gears but for some reason they have different part numbers ... and i kno that the gsr and b16a timing belt is different also so anyways .. can the b16a cam gears be used with the gsr timing belt and water pump ? .. (gsr engine block/head ) .. basicly does the b16a cam gears = b18c1 cam gears ? .. thanks
ps i m using oem timing belt not toda
Old Sep 14, 2006 | 05:03 PM
slomofo's Avatar
GDD Member
Default Re: toda timing belt and cam gears question (blacK_Dc4)
All B-series cam gears are the same.
Old Sep 14, 2006 | 05:17 PM
blacK_Dc4's Avatar
Default Re: toda timing belt and cam gears question (slomofo)
so all b-series cam gears are the same ? .. so i jus have to use the right timing belt/water pump combo right ? .. thanks for the quick response
Old Sep 14, 2006 | 09:32 PM
blacK_Dc4's Avatar
any more suggestions/answers ?
Old Sep 15, 2006 | 12:34 PM
AllmotorJunkie's Avatar
I concur. TODA cam gears are for B Series...meaining B16 and B18
Old Sep 15, 2006 | 12:41 PM
SkoundrelUSA's Avatar
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blacK_Dc4 &raquo;</TD></TR><TR><TD CLASS="quote">so all b-series cam gears are the same ? .. so i jus have to use the right timing belt/water pump combo right ? .. thanks for the quick response </TD></TR></TABLE>
Yes. and Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllmotorJunkie &raquo;</TD></TR><TR><TD CLASS="quote">I concur. TODA cam gears are for B Series...meaining B16 and B18 </TD></TR></TABLE>
Exactly.
Think about all the aftermarket gears that are out there meant for GSRs, B16s, ITRs. All the same.
Old Sep 15, 2006 | 01:49 PM
DonF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blacK_Dc4 &raquo;</TD></TR><TR><TD CLASS="quote">any more suggestions/answers ?</TD></TR></TABLE> Do not do it yourself. Get someone that knows.
98Luder
Apr 8, 2010 06:51 AM
erikiksaz1
Nov 8, 2006 01:05 PM
komat
Jun 12, 2006 02:27 AM
eknine
Oct 27, 2003 12:37 PM
VaporTrail
Jul 29, 2001 10:25 AM
