Amber lights
I did a search but can't find how would I install gauges, Called my friend in Japan last night he said he seen a few around he'll ship back to the states for me. Does anyone know where I can find instructions how would i take apart everything and wiring..
the wiring can be seeen in the DIY, its for a civic, but its the same concept, but the taking apart id suggest a haynes manual, i had to take my dash apart and it helped immensely. There are screws where you'd never gueess
well i couldn't find the link at this moment... i'll try to do a write up soon...
1. remove cluster from car.
2, unscrew each meter, example: gas, temp, rpm, mph. label the screws to each, cause if its the wrong length, there wont be any connection.
3. Buy acetone or nail polish remover, acetone works better.
4. use a Q tip, dipped with acetone and brush it on the bluish greenish side.. be real careful not to touch the front of the cluster.
5. After you're all done, either paint.. or buy LED colored bulbs, the color you desire, I believe the bulb size is 194, there is one bulb you might need to paint, its a very small bulb, forgot the size.
6. Reinstall cluster to its original. and BLING..
I will try to get detailed pictures. Kinda busy.
