Need Some Help
Old Sep 14, 2006 | 03:32 PM
ace42004's Avatar
Default Need Some Help
i just pick up a 89 hatch with a LS swap...the car runs great but if it sits to long, like a day or 2 i have to spray some starter fluid in the TB to get it to start up..but once it starts its all good to go. Just wondering what causes my fuel to dry up..
TIA
Modified by ace42004 at 4:43 PM 9/14/2006
Old Sep 14, 2006 | 11:07 PM
ace42004's Avatar
Default Re: Need Some Help (ace42004)
cant sleep bump..
Old Sep 15, 2006 | 06:31 AM
Loserkidwac's Avatar
Well Sounds like you battery mught just be getting weak and maybe since the starter fluid ignites easier it starts even though you have a weak spark...
Replacing the fuel filer wouldn't hurt and usually over looked, test the battery with a mulit metter should be around 12-13v with the car off and 14-15v with the car running...if it is low w/ the car off the battery is bad or going bad and if it is weak when the car is running then the alt is going bad...make sur eyou charge the batter before testing it too
yeaBuddy
Apr 11, 2011 03:49 AM
hybridctr
Oct 7, 2010 04:55 PM
white-eg
Mar 18, 2010 08:17 PM
flatblk
Jun 9, 2005 09:41 PM
92CivicSIRhb
10
May 4, 2005 11:44 AM
