Clutch On Verge Of Dying?
Old Apr 29, 2002 | 07:19 PM
rurkster's Avatar
Default Clutch On Verge Of Dying?
This might sound like a dumb question but something wrong with my car. Whenever I shift and find a friction point, if I give it too much gas (which really isn't much in this case) i hear a grinding sound (almost like gears grinding), is my clutch about to go is someting else wrong?? Thanks for the help.
[Modified by rurkster, 4:20 AM 4/30/2002]
Old Apr 29, 2002 | 09:55 PM
dlric's Avatar
Default Re: Clutch On Verge Of Dying? (rurkster)
im not an expert or anything but i've driven on clutches that were almost dead. in fact now the clutchmasters stage 3 in my crx is almost completely gone. basically when you shift and give it gas it'll slip..its very obvious. the rpm's will rise and the car won't go anywhere. it will take a few seconds for it to engage. with the crx i was at the point where from a stop, in 1st, i would start up and it would take 10-15 seconds for the clutch to actually engage. so basically i would be sitting there with the car barely moving and the clutch not engaging..and then about 10 seconds afterwards it would finally engage and i could go. if i give the car any more than 25% throttle it'll slip even when im not engaging the clutch. i can be driving along in any given gear, press the gas, and the tach needle would just shoot up and the car doesn't go anywhere. that's a slipping clutch.
Old Apr 29, 2002 | 10:03 PM
RexB16's Avatar
Default Re: Clutch On Verge Of Dying? (dlric)
good LORD! now here is a guy who gets his money's worth out of a clutch!
Old Apr 30, 2002 | 03:15 AM
Rocket's Avatar
Your clutch disc is probably going to go bye bye pretty soon. The hubs loosen and the springs are liable to pop out of the disc
ant13
May 15, 2011 09:06 AM
pd0019
Honda Civic (2006 - 2015)
Jan 4, 2008 05:41 PM
Hebrew-Hammer
Mar 24, 2005 04:08 PM
jhmedcrx
Mar 2, 2005 06:49 PM
camera obscura
Apr 17, 2003 07:22 PM
