1990 300zx for SALE in MD, Perfect Condition
For Sale, 1990 300zx Black exterior Tan interior. 150,xxx miles
Accepting offers or trades, I need more room to carry music equipment.
Exterior:
Black, Flawless no dings,dents
99 Front bumper,99 Tails
No leaks in T-tops
5 Zigen Black/Polish Lip wrapped in brand new Futura Tires
Interior:
Stock tan interior, well kept
JVC Headunit, AUX in
Active speakers all around (Already on car forgot brand)
Nismo Shift ****/Short Shifter
New Z Floor Mats, Pedals
Motor:
Lighten U/D Pulley
Z1 1pc Drive shaft
ASH-Spec ECU
JWT Popcharger
HKS Hi-Power exhaust
The car passes inspection, last inspected may 30, 2006
Things replaced since May (When i took ownership)
2 Faulty Injectors (only replaced 2 cause they where the only ones that
tested poorly)
Steering Rack bushing
Outer tie rods (x2)
Tension Rods (Battleversion)
Reverse Light switch
Injector Harness
New Water Temp Sensor
Front Rotors
Brake pads (x4)
Clutch Slave and Master cyl.
All connections have been cleaned and tested
Rear Main seal
*Car has no lifter tick, runs fine motor has been flushed and 90% of vacuume hoses replaced
** Car does not have the NISMO sticker on it, and Tint has been removed.
No set price on what iam looking for open for offers.
I do have a car fax but its about a year old, though still a clean car fax
Car runs great, A.C works fine, Heat, Cruise Control, Power windows, Steering A OK, Does have stock factory alarm though i do not have the remote.. but it only comes on if you open the locks from the inside when using key to lock door.
email: brian_moyer@comcast.net
AIM: robinlickastores
Exterior:
No leaks in T-tops
Interior:
Motor:
Lighten U/D Pulley
Z1 1pc Drive shaft
ASH-Spec ECU
JWT Popcharger
tested poorly)
Outer tie rods (x2)
Injector Harness
Front Rotors
Brake pads (x4)
Rear Main seal
forgot to add new radiator and thermostat, fuel filter and various fuel lines where installed as well and the rear 300zx center panel lights red when lights are on. No oil/gasket/vacuume leaks, no blow by. Brand new spark plugs, 1 step colder. Recalls have been done by prev. owner. New PTU heads have been checked. Car is throwing no codes.
MarcusFenix
Feb 3, 2013 07:03 AM
st0nedstoopid
Feb 28, 2007 02:28 PM
st0nedstoopid
Nov 27, 2006 06:27 PM
GroundZer0
Dec 19, 2005 08:00 AM
