INTEGRA: How to install rear speakers?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote">The grills are removable, they unclip from the rear.
94</TD></TR></TABLE>
ooh.... do you think i would be able to chenge the speaker through that grill?
Modified by red eye teggy at 6:03 PM 9/14/2006
94</TD></TR></TABLE>ooh.... do you think i would be able to chenge the speaker through that grill?
As long as it's a "standard" 6.5" speaker, [3 hole mount like the stock speaker] and as long as the aftermarket speaker is not too deep.
You may have to remove a little plastic over the top rear mounting screw to make it a little easier, also be careful not to drop the metal clips, (2) they will sometimes slide off the grill "posts" and stay in the clip holes, if they do remove them from the clip holes carefully and reinstall them on the grill posts, make sure they point the right way.
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote"> As long as it's a "standard" 6.5" speaker, [3 hole mount like the stock speaker] and as long as the aftermarket speaker is not too deep.
thanks a lot! i'll try that for sure!
94</TD></TR></TABLE>thanks a lot! i'll try that for sure!
