What motors will work aside from stock?
Old Sep 14, 2006 | 07:34 AM
Kalokohan's Avatar
New User
Default What motors will work aside from stock?
I have a 90 crx hf (D15B6) w/ 220K which is nearing the end of its life. I was wondering what SOHC motors would fit/work without having to get new knuckles for the axles, new engine harness, etc. If I wanted to swap a D16Y8 or D16Z6 in there, what would my shopping list look like?
Thanks!
Old Sep 14, 2006 | 08:54 AM
ck123's Avatar
whast wrong with your engine?
Old Sep 14, 2006 | 09:30 AM
Kalokohan's Avatar
New User
Default Re: (ck123)
It's just old and tired. It's going to need a new tb/wp and all that jazz soon and I'm thinking of just swapping a jdm engine in there since I have friends that work at an engine importing place. I don't want to have to get new knuckles so I'm just asking which engines will swap in and work with relatively small upgrades....it's my beater mind you. I know some of you OG's have this info off the top of your heads.
Old Sep 14, 2006 | 10:05 AM
GsrTurboCRX88's Avatar
Default Re: (Kalokohan)
any d series will fit just fine
Old Sep 14, 2006 | 10:48 AM
LigerZeroWPC's Avatar
Default Re: What motors will work aside from stock? (Kalokohan)
yo, there is a good motor and that doesnt cost much and have good power. its dual cam ZC JDM. bolts right into your car. same mounts, tranny, clutch, mpfi wiring is the same. so all you need is the ecu. the motor runs about 600 avg. but i found mine 450 at Gspeed.com. also mine passed smog even thought it wasn't usdm. they don't even notice.
Old Sep 14, 2006 | 12:54 PM
Kalokohan's Avatar
New User
Default Re: (GsrTurboCRX88)
Will the DOHC ZC swap require me to remove my A/C? I love my A/C.
Old Sep 14, 2006 | 04:34 PM
nope
Old Sep 14, 2006 | 04:41 PM
BlueRex1020's Avatar
Default Re: (LigerZeroWPC)
ogs? wtf? if ur too ignorant on cars n are too lazy to do a simple search then u should respect the people that know n ur asking help from.....yea any d series would fit n if u do z6 or y8 change to ob1.....
Old Sep 14, 2006 | 08:13 PM
ck123's Avatar
d16a6
Old Sep 14, 2006 | 08:37 PM
Tippyman's Avatar
I would reccomend either a SOHC or DOHC ZC motor. You can keep you stock tranny, axles, brakes, AC, mounts, rad. hoses, vac. lines (some may ned plugging.)
All that is needed is slight wiring changes. (search for "mpfi swap")
I did a SOHC ZC swap and it was literally the 1st thing i've ever done to cars other than oil changes. Just do ur research, and check my project thread if ur so inclined, I did extensive coverage of the swap.
Old Sep 15, 2006 | 07:31 AM
Kalokohan's Avatar
New User
Default Re: (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">I would reccomend either a SOHC or DOHC ZC motor. You can keep you stock tranny, axles, brakes, AC, mounts, rad. hoses, vac. lines (some may ned plugging.)
I did a SOHC ZC swap and it was literally the 1st thing i've ever done to cars other than oil changes. Just do ur research, and check my project thread if ur so inclined, I did extensive coverage of the swap.</TD></TR></TABLE>
I have an HF and I believe my wiring is already MPFI, can someone confirm this?
Old Sep 15, 2006 | 07:52 AM
lightcrx's Avatar
yup hf is mpfi. id go with a sohc zc and a si tranny your axels will work, they have the same inners but smaller outers(and bars). later on you might want to upgrade your axels hub and breaks, would be better to do it all at the same time
-joseph
That1guyinvegas
Feb 9, 2014 06:42 AM
james_piggy
Feb 19, 2013 09:57 PM
Meatwad1355
19
Dec 25, 2011 09:00 AM
Chyrio
Classic Hondas
Apr 22, 2011 07:12 AM
EGhatch33
Aug 29, 2005 06:46 PM
