2000 Honda Civix DX 4 Door 321whp and 228 TQ @ 14 PSI SOHC FOR SALE OR TRADE
Old Sep 13, 2006 | 11:32 PM
Quad-Damage's Avatar
Default 2000 Honda Civix DX 4 Door 321whp and 234 TQ @ 14 PSI SOHC FOR SALE OR TRADE
Magazine Car (Honda Tunning July Issue 2006)
CLEAN TITLE!
NO RUST AT ALL!
KKB is $9055 just for the car, STOCK!
Gunmetel 2000 Honda Civic DX 4 DooR
40k on the body
6k on the motor
Pm for more info
BAD, I USE TO DD the car, few dings
THIS CAR ONLY RUNS on 91 OCT GAS, THE CAR IS %100 ABLE TO DD and starts up just fine and RUNS GREAT! MAKES 321 on 91 OCT GAS! 234TQ
Long Key mark on pass side door
Car DOES NOT COME WITH THE CUSTOM MUGEN RNR's
COMES WITH 15 inch BUDDY CLUBS with 225 BFG Drag Radails with %95 left and NEW Dunlops Derizzzas In the Rear and a Black V Cover with a custom Breather
Problems with the car, is just a long key mark on the driver side back door.
Inside in Green
Hood is fading
Paint Match isn't %100
Good, RUNS LIKE A CHAMP, FAST! motor can handel 400whp +
NEW Motor
Oil Changed at 100 Miles, 500 Miles, and Every 1000 miles.
Tranny Flushed 100 miles ago
Never Overheats
16,500 OBO
LOOKING TO TRADE for a 2000 or NEWER, Honda or Acura (NO CIVICS)
Looking to trade + you pay cash or i can throw cash on top
S2000
RSX
Type R's
TSX
1998-01 LS or GS Teg, HAS TO BE %100 STOCK and MINT + a GOOD Amount of Cash on top on your part.
Full D16Y8 Block (REDZONE BUILT)
Darton Sleaves 75mm .20 over 1.6 LITER
Bored, Honed, Decked
Blanced and Blueprinted Block
Wesico Pistons -w- rings, with the coated skirts
Eagle 900HP H Beams Connecting Rods
Crank balanced, polished
ACL Bearings
New Oil Pump (Honda) Shimmed for high flow
New Water Pump (Honda)
New Alternator Honda)
NEW OEM HONDA Heat shield Gasket Intake)
OEM Honda Head gasket
Head
Full D16y8 Head (CLEANED)
9.0.1 comp overall
Redzone P&P 3 angel job both sides, intake and exhaust (SUPER NICE)
D16y8 ARP Head Studs TOruqed to Spec
ZEX Honda D16Y8 - Stage 1 Street/Strip Performance Cam
Ferrea Racing 6000 Series Competition Valves .5 Oversized (YES 6000 SERIES)
Ferrea Racing valve springs
Ferrea Racing Components Titanium Retainers
Tyranny
Rebuild RedZone D16z6 5 Speed
RedZone Stage 3 Clutch
ACT XACT Street Lite Flywheel 11 pound
OBX LSD Beveled so i can take the axles out
ALL NEW OEM HONDA BEARING AND WASHERS Installed and Torqued to Spec
Gator Stage 2/3 Axles 400whp
ARP Extended studs, for mounting my monster 24.5 9 13's slicks
Motor Bolt On's (Other Parts Inside of the Motor Bay)
MSD SCI 10,000RPM
MSD Blaster 2 Coil
2000 Honda Civic MSD Cap and Coil with New Inginitor Setup for MSD
Hondata 3 Bar Sensor (CUSTOM MOUNTED) on Firewall * Car is Runing On 3 Bar 1000 Idel PEFRECT*
2000 D16y8 Engine Harness, Car is All Wired for VTEC (WIRED TUCKED)
2000 Honda Civic D16y8 CUSTOM Sheet METEL MADE POWER MANIFOLD (ported by Redzone) *JET Coated Manifold*
2001 Integra Type R Throttel Body 64mm
AEM Tru-Time Adjustable Cam Gears (Silver) COVERED
AEM Tru-Power Pulleys (Red)
AEM High Performance Fuel Filter (Red)
AEM Fuel Rail (Red)
AEM Fuel Prssure Reuglator (Red)
Walbro 255LPH Fuel Pump
RC 750 sats injectors with OBD 1 Clips
Fluidyne Raditor 1/2 Size for a B Series, Custom Mounted on my D (POLISHED)
Greddy Oil Cooler Kit
Greddy Oil Cooler Lines And Adapters 100 PSI UPGRADED LINES (THESE LINES cost me alot of BANK)
Greddy Water Temp Kit
Custom QuadWarez Ground Hyper Wires
Nology Hot Wire Spark Plug Wires
NGk Stage 3 Colder Plugs Gaped .28
Polished Honda OEM Valve Cover
Password JDM Magnetic Oil Drain Plug (Honda) D16y8
Turbo Setup
Spoolin Performace Turbular D Series Manfoild *ONLY ONE EVER MADE* For a D Series *JET Coated Manifold*
Precision T3/T4 Street & High Performance SC-3427E .57 Trin *JET Coated Housing*
Tail Wastegate 10 PSI 38mm
*JET Coated* Tail BOV 50mm
Spoolin Performace 2.5 inch to 3 inch DMH E-cutout **JET Coated**
Spoolin Performace Oil Feed Lines
Spoolin Performace Oil Return Lines
Spoolin Performace 2.5 inch Charge Pipes POLISHED aluminum
Spoolin Performace Dumptube *JET Coated*
JRC 8 Inch Intercooler *JET Coated*
Suspension
Brembo Front Cross Drilled Rotor System
PBR Ultimate Ceramic brake pads *GREAT PADS*
99-00 Civic JDM Civic Type R E brake cables
01 Acura Integra GSR Rear Disk Brakes
01 Acura Integra GSR Rear Disk AEM Brake Pads (Pads have 5000 miles on em)
Omni Power Full Coilovers with upgraded collers for 700whp
Omni Power Front Camber Kit
Omni Power Rear adjustable camber links, 2 inches in back and 2.2 in front (NOT WASHERS)
Suspension Techniques Speedtech Sway Bar System
Back Strut Polished Bar
Custom Quadwarez High Temp Gunmetel Painted Claipers EX
Custom Quadwarez High Temp Gunmetel Painted Claipers GSR
Zenki Red Extended Lug Nuts 16 4 x 4
ARP Extended Studs for Mounting Slicks
Gator Stage 2/3 Axles 400whp +
Full Race Gold Polished Traction Bar
Polished Hasport Race Mounts 70mm (RACING MOUNTS) Drive Side, Tranny, Rear Engine Mount, Shifter Mounts
Buddy Club P II New Tires 225 15 inch Drag Radails G-force's on the Fronts %95 + left maby 400 miles on them
and Dunlop Durizoes in the Rear 205 %98 left maby 400 miles on them
Car's Inside
2000 Honda Civic Black Si Dash,(Black in color) and FULL Interior (COMPLETE SWAP WITH THE CARS LEGIT VIN) + WITH BLUED TAG! by CHP ALL LEGIT!
Custom Fited, with JDM ARM Rest and custom gauges all black, SUPER SICK INSIDE! + Cutout cookpit button for cutout
2000 Honda Civic Si Climate Control Unit (FULL SI INSIDE, Moon, Sun, Power Roof ALL)
Omni Power Custom detachable hub Quick Relase
Momo Srerring Wheel Hub
Momo Steering Wheel with Bride Logo
Bride ERGO II Black FA [E11ATS] Seats 2 (YES BOTH) in BLACK with Custom Bride Rails
Civic 2 Pod Gugue Holder On Cluster
Defi D-Gauges 52mm 0-35 psi Boost Gauge
Nordskog performance LED Digital Fuel Pressure 0 - 100 psi-RED Display
Fuel Pressure Sending Unit Kit
Summit Digital Gauges 2 1/16 in. diameter, black face, red LED display, voltmeter, water temperature, and oil pressure gauge, digital gauge panel kit
Summit Racing Senders For Voltmete,water temp, and oil pressure
FD Xtreme Bulb 100/130W Platinum White
Black JDM Headlights
Si Gauge Cluster 30k MILES!
OEM 00 Si Shift Boot
2001 GSR OEM Shifter
Skunk 2 Shift ***
Power Door Locks All 4 Doors
Pioneer DEH-P-5500MP 50x 4 (MP3/CD-RW/CD Player)
MB Quarts DKC 169 6.5 in Rear 2x
MB Quarts DKD 113 5.25 in Front 2x
YES I RUN 2 AlARMS (MORE INFO WHEN BOUGHT $2000 + Setup Simular to Lowjack but much better different kinda top secert) Only new onwer will know
Cars Mods on the Outside
Repainted in 2004 Custom GUNMETEL COLOR, SMOKED GRAY
99-00 Crabon Creation Carbon Fiber Front Grill
Sumit Racing Hood Locks
Carbon Fiber Hood, with Hood Locks,Spoon Style.
Carbon Fiber Mugen Front Lip
Lower'd 2.5 inchs
ECU and TUning
Obd 2B to OBD 1 Conversion Harness *Bloomslang*
OBD 1 IAC Sensor
p28 Chiped with CROME PRO STREET TUNED AND DYNO TUNED BY JEARMY and BRANDON from Redzone Performance
P28 Redzone Chiped and Tuned Crome PRO
321whp and 228tq @ 14 psi. RUNS ON 91 PUMP GAS!
HOW THE CAR SITS AS OF TODAY
The Car Makes 321whp and 228torque TO THE WHEELS @ just 14 PSI On a SOHC!
14 PSI! ON 91 OCT!
On my old RIMS!
Handels Great, OLD RIMS
Full RACE T BARS!
S2000 + I pay cash
RSX Type S
Maby a teg, kinda looking for nice, not all out power.
Modified by Quad-Damage at 11:16 AM 9/14/2006
Modified by Quad-Damage at 11:20 AM 9/14/2006
Modified by Quad-Damage at 12:05 PM 9/14/2006
Modified by Quad-Damage at 12:39 AM 9/16/2006
Modified by Quad-Damage at 1:16 PM 9/17/2006
Modified by Quad-Damage at 12:32 PM 9/24/2006
Modified by Quad-Damage at 12:33 PM 9/24/2006
Modified by Quad-Damage at 2:13 PM 9/24/2006
Modified by Quad-Damage at 7:13 PM 9/27/2006
Modified by Quad-Damage at 12:16 AM 10/11/2006
Modified by Quad-Damage at 5:33 PM 10/19/2006
Modified by Quad-Damage at 11:41 AM 10/24/2006
Old Sep 13, 2006 | 11:37 PM
^AM7 putting my car to shame
Loving it on big slicks
Old Sep 14, 2006 | 10:18 AM
added all of my mods, it has alot!
Old Sep 14, 2006 | 10:25 PM
Default Re: (Quad-Damage)
bump
Old Sep 15, 2006 | 11:44 AM
Car Hits VTEC Hard
Old Sep 15, 2006 | 12:30 PM
Markland Photo's Avatar
bump for this car
read this **** last time i picked up the magazine sooooo ht
Old Sep 15, 2006 | 11:37 PM
Default Re: (bulletspastsunset)
Thanks
Old Sep 17, 2006 | 12:03 PM
for tradeeee
Old Sep 18, 2006 | 07:05 AM
Stylinhonda's Avatar
Bump for my one of my fav SOHC turbos
Old Sep 20, 2006 | 04:33 PM
Default Re: (Stylinhonda)
Thanks man, i hate to do it, just not into the game, like i use to be
Old Sep 20, 2006 | 05:50 PM
macDelli's Avatar
nice build
Old Sep 21, 2006 | 10:12 AM
Default Re: (macDelli)
I agree Thanks
Old Sep 21, 2006 | 11:21 AM
boostedbseries2000's Avatar
SLICK LOOK SO GOOD, ANY 1320 TIMES
Old Sep 21, 2006 | 05:44 PM
Default Re: (boostedbseries2000)
the only time i tracking it was a 13.6 @ 109 at just 8 psi havn't seen it on 14
should do 11's on slicks for sure
Just washed and waxed it 2
Old Sep 21, 2006 | 10:26 PM
bump
Old Sep 22, 2006 | 09:43 AM
bump
Old Sep 23, 2006 | 11:22 AM
bumpin
Old Sep 23, 2006 | 12:05 PM
DATZ WEAKSAUCE's Avatar
m4d vtacks
Old Sep 24, 2006 | 11:13 AM
Thanks bumpin
Old Sep 24, 2006 | 11:55 AM
crowder13's Avatar
bump for this healthy looking 4 door civic
Old Sep 24, 2006 | 01:44 PM
Teh_Oven's Avatar
bump for a fast car!
Old Sep 24, 2006 | 02:19 PM
Default Re: (Teh_Oven)
buy this for your family grocery getter it has 4 doors
Old Sep 24, 2006 | 02:28 PM
crowder13's Avatar
^^^ lol that is funny so is mine a grocery getter
Old Sep 25, 2006 | 09:36 AM
Default Re: (crowder13)
Everyone and there mom has a hatch this is just different
Old Sep 25, 2006 | 10:50 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crowder13 &raquo;</TD></TR><TR><TD CLASS="quote">^^^ lol that is funny so is mine a grocery getter</TD></TR></TABLE>
ok fine four doors for the ho's to get in easier hahahaha
