need help
Old Sep 13, 2006 | 09:06 PM
slipperyduck's Avatar
Default need help
i am puttin a 95 bottom end with a 200 head. i have a couple of questions that i need answered if anyone can help.
i want to keep it obdo its a non v-tec head
1. can i use the si wiring harness wit the ecu to run the motor.
2. i have a 89 std dizzy will it work wit the head.
3. and wnything else i need to make it work right in my car
my care is a 89 hatch std dpfi 4 speed.
i have a 91 ecu wit wiring harness
Old Sep 14, 2006 | 02:24 AM
Default Re: need help (slipperyduck)
bump
Old Sep 14, 2006 | 02:14 PM
no one know this sh*t
Old Sep 14, 2006 | 02:18 PM
wiZCo's Avatar
Stouts 'n' Scotch
You haven't gotten any responses because you left out A LOT of info, most importantly:
What kinds of motors are the block and head from?
Post this info and you'll probably have better luck.
Old Sep 14, 2006 | 11:54 PM
Default Re: need help (wiZCo)
sorry its a d16z6 bottom end and a y7 topend
Old Sep 15, 2006 | 06:01 AM
Loserkidwac's Avatar
Are you using your stock intake mani or converting to a multi point one?
If converting look up MPFI conversion in the FAQ at the top, you need to modify your stock harness you can use wires from the si harness but just to modify the stock one....
you will also need to use a 88-91 Dizzy the std won't work, i think hf will but not 100%
Just do the headgasket and timing belt/water pump before you install the motor...I'm not sure which T-belt to use with that combo but start with the y7 belt and see if that works...
IF you need some stuff for the mpfi conversion and a SI dizzy I have all of it pm me
Old Sep 15, 2006 | 01:09 PM
Default Re: need help (Loserkidwac)
i have the ecu and si harness but no dizzy but the thing is will the dizzy work with the y7 head
Old Sep 15, 2006 | 01:11 PM
you may need to cut one of the legs on the dizzy to get it to mount right or I think you could put the a6 dizzy internals in a y7 case and then it would bolt on and plug in correctly
Old Sep 15, 2006 | 08:57 PM
aight
thanks for the info atleast someon helped but y wont my dizzy work?
Old Sep 17, 2006 | 03:11 AM
bump
TravisCadello
Feb 10, 2015 02:27 PM
CRXguy_88
11
Mar 1, 2010 03:47 AM
SQ is the SQUAD
11
Sep 6, 2007 03:54 PM
kingmonkey
Feb 16, 2006 08:27 AM
civic_std
Dec 1, 2005 02:28 PM
