Which valve springs, Rocket gen 1 or gen 2
Old Sep 13, 2006 | 08:24 PM
all-mtr-teg's Avatar
Default Which valve springs, Rocket gen 1 or gen 2
Finally gonna install my blox type b cams in my gsr w/ stock comp. which valve springs should i install the gen 1 or gen 2, I have a set of both. Mostly my daily driver so i won't be reving too much during the week. But it will be getting some track runs hopefully once its tuned.
Old Sep 13, 2006 | 08:44 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: Which valve springs, Rocket gen 1 or gen 2 (all-mtr-teg)
Rocket generally recommends the Gen2's with any cams that are not his. Even though Blox uses good cores.
Old Sep 13, 2006 | 08:46 PM
itralex's Avatar
Default Re: Which valve springs, Rocket gen 1 or gen 2 (rochesterricer)
Gen 2's
I believe Gen1's should be saved for the pure race motors
Old Sep 16, 2006 | 11:17 AM
ah789454's Avatar
use blox spring with blox cams. same if u use toda cams then use toda springs.
cos if something goes wrong the manufacturer is going to ask u what springs u were runing. if u say ????? then they will say our cams arent made to work with those springs. itll save u less headaches.
Old Sep 16, 2006 | 05:08 PM
UncleD's Avatar
Default Re: Which valve springs, Rocket gen 1 or gen 2 (ah789454)
Brilliant post.
cnydc2
14
Feb 16, 2007 06:26 PM
derekhh
Mar 1, 2006 07:27 PM
boy_hapon
Aug 23, 2005 05:46 PM
civic2slo
159
Jul 29, 2005 03:34 PM
Sassafrass
118
Feb 6, 2005 11:44 AM
