CTR pistons in b16a2 block with Type R head questions......
Old Sep 13, 2006 | 07:07 PM
nickel168's Avatar
Default CTR pistons in b16a2 block with Type R head questions......
Hi guys, I just ordered CTR pistons for my b16a2 block. I just want to know if i'm gonna have clearance issues, since I would hate to bent the valves on my type R head. I'll be using the stock rods, and stock head gasket and what else do u guys recommend? My current set up is B16a2 block, ITR head, CTR cams. And I'll be getting it tuned. Thank you very much...
Old Sep 13, 2006 | 10:48 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: CTR pistons in b16a2 block with Type R head questions...... (nickel168)
that is alot of compression.to keep away from partial throttle detonation i would recc some cams with large primary lobes
Old Sep 14, 2006 | 12:04 AM
salman's Avatar
people have may problem with CTr Piston, please do serch for it,
Old Sep 14, 2006 | 12:06 AM
anothersickhatch's Avatar
Default Re: (salman)
your clearances will be fine. as long as the head isnt milled a whole lot you will be ok. i had ctr pistons in my b16 with a head milled 17 thousenths and skunk2 stage 1 cams. i revved that beast to 9 all the time and never had any issues.
CTR PISTONS IN A B16 ARE OK TO USE...i dont see why so many people are having problems with them.
Old Sep 14, 2006 | 12:24 AM
salman's Avatar
Default Re: (anothersickhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anothersickhatch &raquo;</TD></TR><TR><TD CLASS="quote">your clearances will be fine. as long as the head isnt milled a whole lot you will be ok. i had ctr pistons in my b16 with a head milled 17 thousenths and skunk2 stage 1 cams. i revved that beast to 9 all the time and never had any issues.
CTR PISTONS IN A B16 ARE OK TO USE...i dont see why so many people are having problems with them.</TD></TR></TABLE>
Man_EK9
Feb 10, 2008 11:52 AM
lowkeyciv
Apr 25, 2003 03:57 PM
