4th gen center console
Old Sep 13, 2006 | 06:20 PM
pprowler6's Avatar
Default 4th gen center console
i was looking at getting this for my 4th gen but i noticed the e brake would go on the opposite side am i right? and is it possible to get this to work in my car? thanks
Old Sep 13, 2006 | 06:30 PM
TruNinja619's Avatar
Default Re: 4th gen center console (pprowler6)
it is possible.... many have done the conversion before... just gotta move the e-brake assembly... as well as getting a new hazard switch...
Old Sep 13, 2006 | 06:31 PM
pprowler6's Avatar
Default Re: 4th gen center console (TruNinja619)
can i just move the e brake handle or do i have to move the cables and whatnot?
Old Sep 13, 2006 | 06:46 PM
MadCityLude
Guest
Posts: n/a
You need an entirely different ebrake handle. Yours will not work. Also you would be best off getting the cable too. Otherwise you have to rig up the cable somehow.
Old Sep 13, 2006 | 06:57 PM
pprowler6's Avatar
hmm ok is it worth it to you guys or do you think its just to much trouble
Old Sep 13, 2006 | 07:00 PM
MadCityLude
Guest
Posts: n/a
Do the JDM RHD!!
that could be kind of cool actually. That damn ebrake is in my way all the time. With that conversion my wife could deal with it.
If you do you might as well do a writeup while your at it!
Old Sep 13, 2006 | 07:03 PM
pprowler6's Avatar
Default Re: 4th gen center console (MadCityLude)
haha o man i dont think im up for that challenge...what ebrake handle would i need to buy and where u think i could get one?
Old Sep 13, 2006 | 07:04 PM
MadCityLude
Guest
Posts: n/a
I did the 94 conversion in my 92. It wasn't that hard. I wish I had done the RHD now though. EBAY for your parts where else
Old Sep 13, 2006 | 07:08 PM
pprowler6's Avatar
yea i was looking how do i know the difference between the handles
Old Sep 13, 2006 | 07:10 PM
MadCityLude
Guest
Posts: n/a
The seller will tell you if it is JDM for sure. And make sure its 94-96.
Old Sep 13, 2006 | 07:48 PM
M2B4's Avatar
i will be doing this sometime. its best to buy one with full ebrake cable and ebrake and shifter but make sure it has a WORKING cup holder lol
Old Sep 13, 2006 | 08:08 PM
MadCityLude
Guest
Posts: n/a
Default Re: 4th gen center console (M2B4)
^^ are you doing the JDM??
Old Sep 13, 2006 | 08:12 PM
M2B4's Avatar
dont know never seen one for sell and i dont know if ill like it being far away lol got pix?
Old Sep 14, 2006 | 01:53 PM
hp92lude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2B4 &raquo;</TD></TR><TR><TD CLASS="quote">dont know never seen one for sell and i dont know if ill like it being far away lol got pix?</TD></TR></TABLE>
the ebrake is on the right instead of the left. use your imagination
Old Sep 14, 2006 | 01:57 PM
M2B4's Avatar
Default Re: 4th gen center console (hp92lude)
i know that but i wanna c pix...
Old Sep 14, 2006 | 02:03 PM
shutta's Avatar
I have the cables and lever you'll need if you do get that. as well as the console but the cup holder cover is missing..
Old Sep 14, 2006 | 02:37 PM
pprowler6's Avatar
pm'd
Old Sep 14, 2006 | 06:09 PM
SteveoBA8's Avatar
This one? It came with my 94 Jdm BB1 clip, they must have had a disc-changer in there.
Old Sep 15, 2006 | 04:24 AM
hp92lude's Avatar
Default Re: 4th gen center console (SteveoBA8)
jdm yo
Old Sep 15, 2006 | 06:10 AM
ef93si's Avatar
i got the cables, if anyone wants them
Old Sep 15, 2006 | 06:12 AM
M2B4's Avatar
Default Re: (ef93si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SteveoBA8 &raquo;</TD></TR><TR><TD CLASS="quote">This one? It came with my 94 Jdm BB1 clip, they must have had a disc-changer in there.
for sale?
Old Sep 15, 2006 | 11:19 AM
.BigSexy's Avatar
most hood white kid
i had this entire thing for sale a while back, but it sold. U need the console, e-brake assembly, and and cables. that console is from a 94-96 model.
Old Sep 17, 2006 | 08:34 PM
Akhany's Avatar
Default Re: 4th gen center console (egcoupe94)
I did this conversion (not JDM though).
I simply put the ebrake where I thought it should go (withOUT bolting it down), and then put the console over it.
With the console installed, and the e-brake NOT bolted, I got a marker and through the cupholder (i took the cupholder out), I marked where I should drill holes to mount the e-brake.
Take the console out, and drill holes for the e-brake.
So now you have holes to mount the e-brake, but in order to secure it, you need to do is this...
For the holes you drilled for the e-brake, you need to create a hole, or holes, on the SIDE of the already drilled holes for the e-brake. You need to do this so that you can slip in a NUT for the bolts!
If you have a magnet, it could make things much, much easier. I just slipped my finger through the holes I made through the side and held the nut right below the e-brake holes I drilled, and then screwed the bolt in a few turns.
After the nut is on the bolt, all you have to do is tighten it.
I'm too lazy to read over my post to see if I made mistakes, so if you have any questions, just PM me, or get me on AOL IM: Oh Snap Its Ali.
eric416
Mar 13, 2009 05:31 PM
.BigSexy
May 17, 2006 12:06 PM
Jos3ph
Nov 5, 2005 01:47 PM
AgentUT
Apr 30, 2004 12:26 PM
mjensen
Feb 24, 2004 10:20 AM
