My Ek hatch Problems
Old Sep 13, 2006 | 02:13 PM
91blksi's Avatar
Default My Ek hatch Problems
well.. my GAS LIGHT dont work??...anyone know how 2 fix it??
also my brake light comes on and off sometimes...IDONT NEED BRAKeS...anyone know what the deal is...
Just help out
Old Sep 13, 2006 | 02:26 PM
Slothy's Avatar
Default Re: My Ek hatch Problems (91blksi)
My 99 hatch doesnt have a low fuel light, never did. I know coupe and sedans did.
Check your brake fluid, it sounds low. (The movement of the car is raising and lowering the float causing the light to come on during driving.)
Old Sep 13, 2006 | 02:36 PM
nonsense's Avatar
My 99 DX coupe doesn't have a gas light either. I usually fill it up when it gets below the 1/4 mark anyway so it doesn't matter.
Check the fluid and make sure it's full. If it is and you're still getting the light check the wire that goes to the switch on your parking brake handle (#2 in thye pic below). Sometimes the wire comes loose and grounds out causing the light to come on.
Old Sep 13, 2006 | 02:47 PM
JDMFreak's Avatar
Default Re: My Ek hatch Problems (nonsense)
my 00 dx hatch had it on the cluster...i dont remember if it worked or not but i switched to EX because of the tach but here is a picture of a 1996-00 DX gauge cluster:
Old Sep 13, 2006 | 02:57 PM
props_honda85's Avatar
Default Re: My Ek hatch Problems (JDMFreak)
It does have the clear piece in the cluster but it doesnt come on.
Old Sep 13, 2006 | 03:01 PM
FalkenSiR's Avatar
Default Re: My Ek hatch Problems (props_honda85)
Hondas are known for gas lights not coming on. Welcome to the early 90s
Old Sep 13, 2006 | 03:10 PM
hatch96y7's Avatar
Default Re: My Ek hatch Problems (fast95eg8)
yup mine dontcome on either but i got a 96
Old Sep 13, 2006 | 03:14 PM
turboekcivic's Avatar
Default Re: My Ek hatch Problems (hatch96y7)
mines had one
Old Sep 13, 2006 | 04:16 PM
ALL MOTOR DOHC VTEC's Avatar
From: mathematical with a pistol i do trigonometry, CA, U.S.
I have one on my cluster but i use the SI.
I think that it may be a sensor... good luck
EG Hatch 93
Jul 31, 2012 08:23 PM
lunch_box_4_life
12
Sep 6, 2009 06:49 PM
91H4hatch
Feb 17, 2007 07:15 AM
SwampThing
Jan 11, 2005 03:30 PM
