HELP ME!! IM GETTIN ANGERY!! H22 into EG
Old Sep 13, 2006 | 01:27 PM
n2ob16hatch's Avatar
Default HELP ME!! IM GETTIN ANGERY!! H22 into EG
sup honda techor. i need yas help. im in the process of puttin an h22a4 into a eg hatch and i got everything done but for some odd reason its not givin out fuel now. i had a b16 in it before and everything was fine. i hear the fuel pump turnin on. all my grounds are good. ECU has power. gas is fine and have like 1/4 tank left. so i dont know whats the heck is the problem. SOMEONE HELP ME!! need the car runnin.
Old Sep 13, 2006 | 01:43 PM
2fast4u831's Avatar
I'm really 2slow
Default Re: HELP ME!! IM GETTIN ANGERY!! H22 into EG (slowjdmhere)
what have you done so far to check for fuel? let me know
Old Sep 13, 2006 | 01:46 PM
Default Re: HELP ME!! IM GETTIN ANGERY!! H22 into EG (2FAST4U831)
havent checked the main relay. where is that located on the car?
Old Sep 13, 2006 | 01:54 PM
vtecspeed1320's Avatar
Shooting Star
if the main relay was bad it wouldnt prime the fuel pump...
Old Sep 13, 2006 | 01:58 PM
2fast4u831's Avatar
I'm really 2slow
Default Re: (vtecspeed1320)
I think that your fuel rail is not getting any fuel. The fuel might be getting trapped somewhere check and double check
Old Sep 13, 2006 | 01:59 PM
sometime the fuel pump primes and sometime it doesnt.. what migth ya think is the problem. this is gettin me upset. been up all night tryin to figure it out. the car cranks and has sparks. cam timin and ignition is set and good. are you supposed to repin anything on the ECU harness?
Old Sep 13, 2006 | 02:06 PM
Default Re: (slowjdmhere)
i dont think im gettin any fuel at all. i left the fuel filter on the firewall open and cranked it and fuel dont come out of there too.
Old Sep 13, 2006 | 02:28 PM
2fast4u831's Avatar
I'm really 2slow
check the grounds. the one on the tranny, valve cover and specially the one on the thermostat housing
Old Sep 14, 2006 | 02:45 AM
Default Re: (2FAST4U831)
i have checked all my grounds. the one on the valve cover tranny and thermostat housin. this sucks lol. thanks for all the help guys. but imma change out the main relay and see whats up. i'll keep ya updated
Old Sep 14, 2006 | 04:49 AM
2point2's Avatar
what ecu?
Old Sep 14, 2006 | 11:12 AM
Default Re: (2point2)
im usin chiped p28
Old Sep 14, 2006 | 11:00 PM
MAN!!! i checked the main relay just now and it seems to be work. i took the main relay out and turn the ignition and plugged it back in and i hear the fuel pump primin.. so far i checked. fuel pump. it works. ecu is gettin power. all my grounds are good. theres enough fuel in it to start (1/4 tank) i checked the gas and its still good. cam timing and ignition is good. its gettin sparks. but for some reason its not gettin fuel!!! its pissin me off. im bout to drop kick the dang thing. SOMEONE HELP ME!
Old Sep 14, 2006 | 11:10 PM
AMS MIKE's Avatar
crack open the 22mm nut to the line on the rail and prime the car. you see fuel?
if not.
-check main relay under dash (as others said)
-check fuel pump (MAKE SURE THE FILTER DID NOT COME OFF INSIDE YOUR TANK)
-check all wiring, make sure its all un-cut
Old Sep 14, 2006 | 11:16 PM
Default Re: (AMS MIKE)
yepp i did checked it. i left the fuel line that runs from the fuel rail to the fuel filter un bolt and i see no fuel spray out when i turn the key.
Old Sep 14, 2006 | 11:17 PM
AMS MIKE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowjdmhere &raquo;</TD></TR><TR><TD CLASS="quote">yepp i did checked it. i left the fuel line that runs from the fuel rail to the fuel filter un bolt and i see no fuel spray out when i turn the key.</TD></TR></TABLE>
THEN....
-check main relay under dash (as others said) check voltage and if it clicks
-check fuel pump to see if its getting power
Old Sep 14, 2006 | 11:31 PM
i did checked all that. no wires un-cut. i checked the main relay. and its good. i pulled it out and turn the key and my check engine light stayed on. meanin the ecu had no power and when i plugged back in with the key turn to on. the check engine light turned off and the fuel pump prime. i changed the fuel pump three time. i have a typeR fuel pump stock fuel pump and a walbro. i tried all three and it all worked. the filter didnt fall off.
Old Sep 14, 2006 | 11:32 PM
AMS MIKE's Avatar
put gas in the car. make sure you are NOT on a hill.
change your fuel filter
Old Sep 15, 2006 | 12:13 AM
2fast4u831's Avatar
I'm really 2slow
are you sure the gas gauge isnt broken?
check for any fuel leaks
Old Sep 15, 2006 | 01:36 AM
lol there is gas in it. whenever i take the fuel pump out the filter on the pump is soak and wet of gas.
Old Sep 15, 2006 | 05:05 AM
2point2's Avatar
maybe the return and feed lines are switched?
take off both and turn on the pump.. have the lines inside small bottles or something..
Old Sep 15, 2006 | 06:27 AM
the line that goes to the fuel regulator? which one you means
Old Sep 15, 2006 | 08:04 AM
2fast4u831's Avatar
I'm really 2slow
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowjdmhere &raquo;</TD></TR><TR><TD CLASS="quote">the line that goes to the fuel regulator? which one you means</TD></TR></TABLE>Yea that one Have you also disconnected the fuel line before the fuel filter?
Old Sep 18, 2006 | 05:17 PM
i did what you told me and still i get no fuel.. anyone? help
Old Sep 18, 2006 | 10:56 PM
AMS MIKE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowjdmhere &raquo;</TD></TR><TR><TD CLASS="quote">i did what you told me and still i get no fuel.. anyone? help</TD></TR></TABLE>
Jump the yellow/green fuel pump wire to power and see if fuel comes out.
Old Sep 18, 2006 | 11:07 PM
2point2's Avatar
man, someone from texas help this guy out! lol.. it's probably so simple.
