HELP my car acted like rev limitor at 3400 now wont start
Old Sep 13, 2006 | 01:23 PM
ftrtuner's Avatar
Default HELP my car acted like rev limitor at 3400 now wont start
i had my friend do a wire tuck and the dpfi-mpfi because he knew how to do it and i dont like messing with wires to much but when he was finished i was driving it around and that night it ran fine but then it acted like the rev limitor was at 3400 and and now it wont start back up again what could be the problem i switched ecu and still nothing, checked distributor checked plugs and wires... i have a feeling my timing jumped but anything would help
Old Sep 13, 2006 | 01:37 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: HELP my car acted like rev limitor at 3400 now wont start (ftrtuner)
check timing
Old Sep 13, 2006 | 01:39 PM
xDicktonesx's Avatar
Default Re: HELP my car acted like rev limitor at 3400 now wont start (mar778c)
oh, so its a clean *** wire tuck but it doesnt run? you should join AM7.
start at the dizzy and trouble shoot your way outward.
Old Sep 13, 2006 | 02:00 PM
ftrtuner's Avatar
Default Re: HELP my car acted like rev limitor at 3400 now wont start (xDEFTONESx)
ya its a clean wire tuck but ya it doesnt run it ran the whole day but right before i was bout to go home it started doing this
Old Sep 13, 2006 | 08:21 PM
Rukusmasta2's Avatar
you should be throwin a code 4 wchich is ckp(crankposition sensor) that will throw ur car into safe mode and usually means ur dizzy is fucked up. but double check ur wiring cuz thats what was wrong with mine, had OBD0-1 conversion harness and where i believe c1 went to on the obd0 plug i cut and connected it to the wire coming out and fixed it, lol
Old Sep 13, 2006 | 08:31 PM
1 Fly SI's Avatar
Default Re: HELP my car acted like rev limitor at 3400 now wont start (Rukusmasta2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rukusmasta2 &raquo;</TD></TR><TR><TD CLASS="quote">you should be throwin a code 4 wchich is ckp(crankposition sensor) that will throw ur car into safe mode and usually means ur dizzy is fucked up. but double check ur wiring cuz thats what was wrong with mine, had OBD0-1 conversion harness and where i believe c1 went to on the obd0 plug i cut and connected it to the wire coming out and fixed it, lol </TD></TR></TABLE>
sounds like your in limp mode try changing the distributor
jdm_da9_1993
Aug 14, 2011 12:18 PM
95blackEG
Dec 28, 2008 08:40 PM
scspeed
Sep 14, 2008 06:52 PM
hoo my gosh
May 8, 2008 05:56 PM
TypeR0207
Jun 20, 2002 05:26 AM
