Car gets hot- 94 Civic EX
Old Sep 13, 2006 | 12:49 PM
Raider504's Avatar
Default Car gets hot- 94 Civic EX
Not much of a car buff here but I need help, when I have the car in park or just at a total stop the engine gets hot fast but when im just driving regularly it is fine. What might be the problem?
Old Sep 13, 2006 | 12:53 PM
-Gary-'s Avatar
Default Re: Car gets hot- 94 Civic EX (Raider504)
Does your radiator fan go on and off?
Old Sep 13, 2006 | 12:55 PM
egsleepercivic's Avatar
x2
check to make sure the fan is turning on
Old Sep 13, 2006 | 01:30 PM
eeleaj's Avatar
Default Re: (egsleepercivic)
yeah if that what it does its most likely the radiator fan or fan switch
Old Sep 13, 2006 | 02:03 PM
ablack934doorcivic's Avatar
Default Re: (eeleaj)
it could also be the thermostat
Old Sep 13, 2006 | 02:59 PM
FalkenSiR's Avatar
Default Re: (ablack934doorcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ablack934doorcivic &raquo;</TD></TR><TR><TD CLASS="quote">it could also be the thermostat</TD></TR></TABLE>
True, but not likely. It would overheat either way if the thermostat was bad.
Check your fuses, then relay, then fan wiring
Old Sep 13, 2006 | 03:31 PM
Default Re: (fast95eg8)
to some degree it would not be as high because the air hitting the radiator. it would probally keep it just below the hot line. but i do agree check fan switches and relays.
nfiniti9
Jun 9, 2012 02:14 PM
yungvl
Jul 2, 2011 03:56 PM
clair
Aug 12, 2009 09:24 AM
SpoonREVS
Jan 24, 2006 05:42 PM
IrOcKtHeVOrTeC
Mar 15, 2005 10:33 AM
