onmipower sport (12kfront, 10krear) coilovers work ok for drag?
I'am looking at getting some coilovers. The car is a turbo crx. I want a coilover that will have decent street manners and not have the rear hop out everytime I hit a bump and handle decent. I was thinking the omnipower sports would be a good balance.
Will they hookup decent on the track?
The stiffer springs in the rear will help a bit at the track, but regardless, that shock setup is awesome on the track. I run the Omni drag setup on my car and they work great. Consistent sub 1.6 60's on 24" tires and 9.62 1/4 mile!
wich one will he be able to use? they don't list one for the crx
http://www.omnipowerusa.com/Pr...s.asp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wfocrx »</TD></TR><TR><TD CLASS="quote">I'am looking at getting some coilovers. The car is a turbo crx. I want a coilover that will have decent street manners and not have the rear hop out everytime I hit a bump and handle decent. I was thinking the omnipower sports would be a good balance.
Will they hookup decent on the track?</TD></TR></TABLE>
I'm running the sports on my Integra. I swapped the rates around, running 12k in the rear and 10k up front. Definitely reduced a lot of squat. However, daily driving, the front end feels too wobbly now with the softer springs. Plus, the added weight from the turbo and other components don't help either. I'm considering puttin the 12k back up front and running the 10k in the back, just so i can feel safer when im driving on the freeway.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 »</TD></TR><TR><TD CLASS="quote">wich one will he be able to use? they don't list one for the crx
http://www.omnipowerusa.com/Pr...s.asp</TD></TR></TABLE>
http://www.omnipowerusa.com/Pr...r.asp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wfocrx »</TD></TR><TR><TD CLASS="quote">Thanks; but, I already know about the drag rears. I was wondering about the sport coilover though.</TD></TR></TABLE>
The sports should ride a lot better than the drags, just less spring and looser valving.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rip94delsol »</TD></TR><TR><TD CLASS="quote">just wandering tony1 whats the spring rate on your setup?</TD></TR></TABLE>
Their off the shelf drag kit, i think it's 12k front and 18k rear?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">The drags will only be slightly better than the sports at the track. </TD></TR></TABLE>
Wow, thats good to know....I've made several posts regarding this in the EF/CRX section and never get a decent answer
I'm glad someone is able to clarify.
EDIT: And how do those "adjustable" coilovers compare to the regular full coilovers? Is that adjustability really important for a street/strip setup?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">The stiffer springs in the rear will help a bit at the track, but regardless, that shock setup is awesome on the track. I run the Omni drag setup on my car and they work great. Consistent sub 1.6 60's on 24" tires and 9.62 1/4 mile!</TD></TR></TABLE>
Tony I thought you didnt like Omni's cause what happen to a drag car due to omni's?
if it is a drag car only, then the drag rears rock!! But for daily the 18K spring hurts the kidneys.
I run the sports 12k front 10k rear in a teggy. yes it does squat a little. But a good street/track set-up that does not beat you up.
Daily driven 11.3@129 @ 20psi
Joshua
SlowMotion Motorsports
Joshua
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wfocrx »</TD></TR><TR><TD CLASS="quote">yeah, I think Iam going to get the sports.
Do you think I could still hit 1.7-1.8 60' with slicks+traction bar, MM inserts and 250whp?</TD></TR></TABLE>
u could pull better 60's than that. with good seat time,
i also run omni's and love them, have them on track and street car. both have drag set up omni's 12k and 18k
