coolant turns a darker color after a few days? whats going on here
Old Sep 13, 2006 | 12:10 PM
blackeg's Avatar
Default coolant turns a darker color after a few days? whats going on here
this is my friends stock gsr with 130k miles. compression was around 220 so it appears healthy. peakboost kit on 9 psi a/f 11.8:1 down to 11:1 at redline, timing is around .9* per psi retard.
his coolant in the reservoir turns a golden shade after a few days. i dont think its oil, because oil and coolant dont mix very well and wouldnt form a homogenous mixture. this has the same tint and consistancy throughout. it dont smell like oil, but it smells like shitty *** old coolant, which isnt the case because it only has a few 1000 miles on it since it was flushed.
the car runs fine and doesnt appear to be burning much if any coolant or oil, nor is it pressurizing the overflow. whats going on here
Old Sep 13, 2006 | 12:23 PM
umop-apisdn's Avatar
Default Re: coolant turns a darker color after a few days? whats going on here (blackeg)
It's probably mixing with the old coolant leftover in the block. What flushing procedure was followed?
Old Sep 13, 2006 | 06:21 PM
blackeg's Avatar
Default Re: coolant turns a darker color after a few days? whats going on here (umop-apisdn)
the block was not flushed. the coolant was drained however, and the oe rad replaced with a fluidyne unit.
also, the fluidyne was full of coolant hooked up to another car that sat for probably a year or 2. i know they are aluminum, but could there be corrosion or something inside the rad that would discolor the coolant?
Old Sep 13, 2006 | 06:57 PM
qfast817's Avatar
was it fill up with water on the other car?
Old Sep 14, 2006 | 02:13 AM
blackeg's Avatar
Default Re: coolant turns a darker color after a few days? whats going on here (qfast817)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qfast817 &raquo;</TD></TR><TR><TD CLASS="quote">was it fill up with water on the other car?</TD></TR></TABLE>
50/50 coolant water mix in the other car.
i actually am not too too concerned, but the owner wanted me to find out more information
Old Sep 14, 2006 | 05:00 AM
4thgenx42's Avatar
Check to see that it isnt mixing with oil.
Old Sep 14, 2006 | 12:38 PM
blackeg's Avatar
Default Re: (4thgenx42)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4thgenx42 &raquo;</TD></TR><TR><TD CLASS="quote">Check to see that it isnt mixing with oil. </TD></TR></TABLE>
yea i did, oil looks fine.
oranginal
Mar 30, 2009 07:39 AM
dtran002
Aug 25, 2008 07:41 PM
MattyDA
Jan 29, 2006 01:15 PM
94gsr18kid
Dec 29, 2004 08:12 AM
hybridb18
Aug 6, 2003 09:00 PM
