Auto to manual tranny swaps...
hey ... whats up... anyways i have a 93 civic dx hatch that is a sad sad auto... my car has got really high mileage so im thinkin about doing a motor swap... a d15b or ls most likely... i was just wonderin how hard it would be to change the tranny from auto to manual.... seeing as im gonna have to cut holes and stuff for petals... thanks .....
Things you will need for a manual transmission to go into a car that was originally an automatic.
Clutch disc
flywheel
pressure plate
throwout bearing
Throttle cable
transmission mounts
starter
Clutch master and slave cylinders
complete manual transmission
pedal assembly
clutch lines
shifter arm
shift linkages
shifter bushings
an ECU from a manual car with the motor you are going to install
Clutch disc
flywheel
pressure plate
throwout bearing
Throttle cable
transmission mounts
starter
pedal assembly
clutch lines
shifter arm
shift linkages
shifter bushings
