timing off 1/2 degree...ok to drive on?
Old Sep 13, 2006 | 11:53 AM
Sumslapper's Avatar
Year 3030
Default timing off 1/2 degree...ok to drive on?
Ok the other day i pulled off a 94 ls head and put on a 2000 ls head and changed out a busted headgasket so i can pass smog. I think i may have or must have stretched the timing belt either when i put it back on or off. Everytime i line the gears up and crank perfect, the timing retards itself about a half of a degree everytime. ( i did the timing like 10 times to make sure) my idle is kind of rough, it tends to rev back and forth between 300rpms and 800rpms when warmed up. The car doesnt bog/die and the powerband is smooth through all the rpms when driving it, it just makes me a little concerned knowing my timing is not 100% perfect. thanks for any input/experience
Old Sep 13, 2006 | 12:44 PM
Sumslapper's Avatar
Year 3030
Default Re: timing off 1/2 degree...ok to drive on? (sumslapper)
help
powerstrokeaaro
Aug 21, 2010 06:30 PM
miguey310
Aug 21, 2010 09:20 AM
dohcgarage@714
Mar 19, 2007 10:45 PM
chrisnova
Aug 20, 2004 01:08 PM
