What could this be a symptom of? Please read inside.
Ok, my D15b VTEC has a wierd thing it does. Here's the scenario, if i were to go to 4,000 RPMs in 1st gear then shift to neutral to let it idle its smooth and consistent. But, if i go past 5,000 RPMs into vtec and do the same thing the idle will bog some and almost want to die but fixes itself after 10-15 seconds. Could this be a clogged vtec solenoid that isn't letting the pressure off fast enough and its "stuck" in vtec?
Metal Head
10
Aug 2, 2006 12:58 PM
