Cheap tire sites for 195-60-14s
Old Sep 13, 2006 | 09:44 AM
HBK's Avatar
HBK
Default Cheap tire sites for 195-60-14s
I'm trying to find the cheapest online tire site that delivers.
I'd like to get 195-55-14s but they don't seem to exist. Where can I get some cheap but performance intended tires? I'm looking to spend anywhere from 35-50 for a tire. Preferably an older set of RT215 Azenis, or the RT615 azenis.
Old Sep 13, 2006 | 11:36 AM
FalkenSiR's Avatar
Default Re: Cheap tire sites for 195-60-14s (HBK)
Azenis are your best bet for a performace at that size. Make sure they're not too old.
A friend used to have 195-50s in his ek coupe, mounted on steelies. Those things were PHAT
Old Sep 13, 2006 | 12:20 PM
HeedLessInc's Avatar
Default Re: Cheap tire sites for 195-60-14s (fast95eg8)
tires.com
Old Sep 13, 2006 | 12:21 PM
HBK's Avatar
HBK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast95eg8 &raquo;</TD></TR><TR><TD CLASS="quote">Azenis are your best bet for a performace at that size. Make sure they're not too old.
A friend used to have 195-50s in his ek coupe, mounted on steelies. Those things were PHAT </TD></TR></TABLE>
Man I would love to find a set of RT-215 azenis. I once had a pair for 14" crx si rims and I loved them. I can barely afford the new stuff.
Old Sep 15, 2006 | 02:48 PM
nsxtasy's Avatar
H-T Order of Merit
14" tires are some times more expensive than 15" tires.
The Azenis cost $61 each in 195/60-14 but they won't last very long, maybe 10-12K miles. You can get the Yokohama ES100 and they'll last three times as long as the Azenis, and will perform better in rain (but the Azenis is much stickier on dry pavement). The ES100 is $72 for 195/60-14 (best 14" size for Integras and '97-00 Civic) and $69 for 185/60-14 (best 14" size for pre-'96 Civics).
For $35-50 per tire, all you're going to get is crap.
Old Sep 17, 2006 | 05:02 PM
mini-e's Avatar
not cheap- but the best sizing i xcould find for hx rims (195 55 14). i need to wear out my ziex before i buy these, but they are highly rated tires and the diameter matches up.
http://www.1010tires.com/tire....45620
Old Sep 17, 2006 | 07:20 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Cheap tire sites for 195-60-14s (mini-e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mini-e &raquo;</TD></TR><TR><TD CLASS="quote">not cheap- but the best sizing i xcould find for hx rims (195 55 14). i need to wear out my ziex before i buy these, but they are highly rated tires and the diameter matches up.</TD></TR></TABLE>
The diameter of that size is really small and doesn't match up as well as other sizes for most Honda/Acura cars. For example, on CRXs, del sols, and pre-'96 Civics that came with 175/70-13 tires stock, 185/60-14 is a much better match than 195/55-14. Also, the Toyo T1-R is a decent tire, but you can get the Yokohama ES100, which is very similar in performance, in 185/60-14 for less money ($69/tire at the Tire Rack).
What kind of car do you have (model, version, and year)? And why are you so hung up on getting the wrong size tires for your car?
If you insist on getting those undersized, overpriced Toyo tires, you'll find that the prices are a lot cheaper, and you won't have to pay as much in shipping or anything in duty, if you get them from a dealer in the States, like http://onlinetires.com (where they're $75, vs $85 at the Canadian dealer in your link).
Old Sep 17, 2006 | 07:39 PM
mini-e's Avatar
Default Re: Cheap tire sites for 195-60-14s (nsxtasy)
195 55 14 is less than 1% smaller, 185 50 14 is less than 1% bigger.. i can live with either and i think i'll give the toyo's a shot- the avs are pretty noisey and are few years older in design. i'll try the toyos, people like them and i want to check them out. thanks for the link to the better prices!
Old Sep 17, 2006 | 07:51 PM
DC4 Dave's Avatar
VulcanTire.com
They've got the Azenis RT-615 in 195/60-14 flavor for $64 each, currently.
Any cheaper, and I'd reccomend the Fuzion HRi - great all-around tire, for the price.
Old Sep 17, 2006 | 08:25 PM
HBK's Avatar
HBK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">The diameter of that size is really small and doesn't match up as well as other sizes for most Honda/Acura cars. For example, on CRXs, del sols, and pre-'96 Civics that came with 175/70-13 tires stock, 185/60-14 is a much better match than 195/55-14. Also, the Toyo T1-R is a decent tire, but you can get the Yokohama ES100, which is very similar in performance, in 185/60-14 for less money ($69/tire at the Tire Rack).
If you insist on getting those undersized, overpriced Toyo tires, you'll find that the prices are a lot cheaper, and you won't have to pay as much in shipping or anything in duty, if you get them from a dealer in the States, like http://onlinetires.com (where they're $75, vs $85 at the Canadian dealer in your link).</TD></TR></TABLE>
I drive a 91 crx si and stock is 185-65-14 so I'd like to step up to a 195 55 or 60-14 to put on my 14" panasports as they are wider then stock crx rims
Old Sep 17, 2006 | 09:11 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mini-e &raquo;</TD></TR><TR><TD CLASS="quote">195 55 14 is less than 1% smaller</TD></TR></TABLE>
No, it isn't. It's 1.3 percent smaller than your stock size, 185/60-14. That's TOO SMALL.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mini-e &raquo;</TD></TR><TR><TD CLASS="quote">the avs are pretty noisey and are few years older in design.</TD></TR></TABLE>
Actually, the Toyo T1-R is just as old as the ES100. They've been out for several years overseas. Toyo just hasn't introduced them in the States until recently. However, the age of a tire's design is rarely an important factor as to their performance; just to cite one example, look at how well the S-03 compares with most of the tires introduced since then.
Also, the ES100 isn't noisy at all, when they're new. They can get noisier when they wear down, but so do other tires; often, the noise is caused by uneven wear due to suspension problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mini-e &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the link to the better prices! </TD></TR></TABLE>
Hey, whatever you get, you shouldn't pay more than you have to!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA3 Dave &raquo;</TD></TR><TR><TD CLASS="quote">They've got the Azenis RT-615 in 195/60-14 flavor for $64 each, currently.</TD></TR></TABLE>
195/60-14 is too big for his car, but the RT-615 is supposed to be out any day now in 185/60-14. However, he may not want a tire that wears so quickly or doesn't do so well in rain.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA3 Dave &raquo;</TD></TR><TR><TD CLASS="quote">Any cheaper, and I'd reccomend the Fuzion HRi - great all-around tire, for the price.</TD></TR></TABLE>
The Fuzion HRi is an all-season tire, whose performance is much worse than all of the tires previously mentioned in this topic. He didn't say anything about using the tires in snow, so I can only conclude that he's not looking for all-season tires. And if he were, there are all-season tires that are WAY better than the crappy HRi.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HBK &raquo;</TD></TR><TR><TD CLASS="quote">I drive a 91 crx si and stock is 185-65-14</TD></TR></TABLE>
No, stock on your car is 185/60-14.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HBK &raquo;</TD></TR><TR><TD CLASS="quote">I'd like to step up to a 195 55 or 60-14 to put on my 14" panasports as they are wider then stock crx rims</TD></TR></TABLE>
Go ahead, if you want. I wouldn't, though, if it were my car. (Then again, if it were my '91 CRX Si, I'd go get some 15" wheels. The Kumho SPT is only $41/tire after rebate in 195/50-15, which is the proper 15" size for your car. You'd save $136 just on that one set of tires, compared with those Toyos, and that's almost enough to buy a decent used set of 15x6 wheels.)
PinoyDelS0l
Jul 11, 2008 02:47 PM
unpredictableacts
Sep 25, 2006 10:25 PM
silversurfer2282
Suspension & Brakes
Jan 25, 2005 01:41 PM
thrty8street
55
May 26, 2004 10:05 AM
onyx00
Sep 28, 2002 08:11 AM
