blox cams:competition series vs tuner series?
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice »</TD></TR><TR><TD CLASS="quote">Competition series is equivlent to the Pro series from Skunk, tuner series is the standard series from Skunk.</TD></TR></TABLE>
That is totally wrong, the compition series just has a wider small lobes, for a wider contact patch.
Well from I see the comp. series has taller primaries? meaning more lift compared to the others??? Pix dont do much but IMO the comp. would give u greater mid range due to having more on the primaries...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Natural Aspirations »</TD></TR><TR><TD CLASS="quote">
That is totally wrong, the compition series just has a wider small lobes, for a wider contact patch. </TD></TR></TABLE>
Blox cams are made from stock blanks so they have the same lobe width as stock.
i spoke with a blox rep, and simply put, he said the power differences b/w the two are the same with the comp series being slightly easier on the valvetrain bc of the wider lobes.
just go to the blox site they have the spec there and you can see the difference. It dosent matter anyways if they make more power you have to pick the cams that suits your set up (EX. Blox cmp type C will do **** in a stock b16 compared to CTR) So choose according to setup and usepower rang buy looking at the spec sheet so you need to let us know your setup before the ?canbe answered. But good luck on chooseing teir are alot of cams out their now adays
JDM_EK4_Coupe
Apr 15, 2007 07:50 PM
blox, bloxs, cam, cams, camshaft, camshafts, comp, comparison, competition, compettion, difference, series, tuner, tunner, type
