How do you replace the oil pan on a GSR?
Old Sep 13, 2006 | 09:24 AM
SlammedBlackGSR's Avatar
Default How do you replace the oil pan on a GSR?
I have a GSR but i bought an LS oil pan..........is it easy to replace? Isnt the 8 bolts around the oil pan, just take them off and the oil pan is off?
Old Sep 13, 2006 | 09:31 AM
yee SERIOUS's Avatar
negative. your ls oilpan is not interchangable with gsr/itr's. the pan is slightly different due to the oil pump i believe. so you need to get a gsr (p72) oil pan. the oil pan gasket is the same though. remember get a new oil pan gasket and hondabond/gasket sealer.
gsr oil pan = itr oil pan
ls oil pan = b16 oil pan
and to swap the pan, you have to undo all the bolts. there's like 18 of them i think. i forget the exact number, but there's a lot that go all the way around. you'll have to remove the piece covering under the oilpan that is next flywheel/tranny. you'll see when you get under the car.
Old Sep 13, 2006 | 09:50 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: (undercoverdc2)
^ yep
SlammedBlackGSR
Sep 13, 2006 09:36 AM
DXK Eg
Feb 24, 2005 10:28 AM
LAKER HATER
May 21, 2004 07:51 AM
