Dyno Testing - BPi Flow Stack & Injen Velocity Stack Filter
Details:
Intake - 3" Injen Shortram Intake (Part No. INJ-IS1420P)
Engine - B18C (GSR) Engine Bored to 84mm (Stock GSR Crank), Stock ITR Head, Skunk2 Stage 2 Cams, Edelbrock Intake Manifold, 68mm TB, Tri-Y Header
Dyno Type: Dynapack Chassis Dynometer
The engine was tuned with the BPi Stack first, but note A/F ratio maps indicate no significant changes in A/F ratios. Air Temperature was also logged (I did not post), but both passes were within 2/10s of a degree F through through both passes.
Legend:
Red = BPi Flow Stack
Green = Injen Filter with Built-in Velocity Stack
Thanks to all my customers providing test data.
Legend:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stealth1 »</TD></TR><TR><TD CLASS="quote">definitely a quality product, because I know it will be asked....did the BPi stack have a filter on or not?</TD></TR></TABLE>
I'm waiting on that clarification myself.
Bryan,
i will be testing your flowstack with my h22 on October 21st. Any particular filter you would like me to try to get and compare it to? All i have access to right now is a no name filter and a 3 year old K&N
if someone will send me an apex'i filter, i will test it and send it back to you. I'm getting on the dyno for an hour just to nit pick at my timing. I'd guess it will take a maximum of 30 or so minutes to do that, then spend the other 30 minutes doing a comparison.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">Bryan,
An oem honda s2000 filter.
</TD></TR></TABLE>An oem honda s2000 filter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junbb1 »</TD></TR><TR><TD CLASS="quote">An oem honda s2000 filter.</TD></TR></TABLE>
its a 3" cone?
its a 3" cone?
Got the info on this. Disappointing as it is, test was without a filter, which can certainly represent a bias, though from testing I have seen its small, referencing the following dyno plot: http://www.bpinitiatives.com/images/test_04.jpg
I will do another dyno filter on vs filter off when I hit the rollers within the next two months also.
to Bryan for a great product
one question though, is it absolutely imperative that the edge of the plastic that goes into the coupler to the intake be completely flush with the metal of the intake tube, would a gap there create turbulence and negate some of the effects of the filter??
to Bryan for a great productone question though, is it absolutely imperative that the edge of the plastic that goes into the coupler to the intake be completely flush with the metal of the intake tube, would a gap there create turbulence and negate some of the effects of the filter??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 »</TD></TR><TR><TD CLASS="quote">one question though, is it absolutely imperative that the edge of the plastic that goes into the coupler to the intake be completely flush with the metal of the intake tube, would a gap there create turbulence and negate some of the effects of the filter??</TD></TR></TABLE>
I need to exercise caution in answering this one.
A small gap or lip (from ID difference) can potentally cause seperation of the boundary layer at the "defect". That said, the significance of this "flow disturbance" is probably null (ie. zelch). The benefit of the stack is controlling the flow around the inlet and into the tubing.
For the **** enthusiast (myself included) I would recommend positioning the stack in contact with the tubing to minimize the gap and maybe use a knife (or dremel) to clean up any sharp corners or edges at the junction of the stack and tubing. Of coarse do this with the intake off the car and clean it thoroughly so you are not dumping plastic or aluminum debris into your combustion chambers.
A small gap or lip (from ID difference) can potentally cause seperation of the boundary layer at the "defect". That said, the significance of this "flow disturbance" is probably null (ie. zelch). The benefit of the stack is controlling the flow around the inlet and into the tubing. For the **** enthusiast (myself included) I would recommend positioning the stack in contact with the tubing to minimize the gap and maybe use a knife (or dremel) to clean up any sharp corners or edges at the junction of the stack and tubing. Of coarse do this with the intake off the car and clean it thoroughly so you are not dumping plastic or aluminum debris into your combustion chambers.
B16CRXT
94
Sep 28, 2014 07:17 AM
jdmcoop
Jun 19, 2011 08:56 PM
CrisEK
Honda Civic (2006 - 2015)
30
Apr 26, 2011 12:08 PM
SonicK20Z
Jun 13, 2006 05:20 AM
