b16a or b18c head?
Old Sep 13, 2006 | 08:43 AM
REKOX13's Avatar
Default b16a or b18c head?
I have a b18c block with ctr pistons, skunk2 stage 2 cams, skunk2 itm, bdl throttle body...currently im running the b18c head, but i also have a b16a head sitting in my garage...i have been told a couple different things about which one to use, just want to hear some ups n downs from the HT peeps....also, whats technically the highest i can rev out a b18c with the b18c head without causing trouble?>
Old Sep 13, 2006 | 09:31 AM
ViF CrX's Avatar
Default Re: b16a or b18c head? (REKOX13)
if you throw the b16 head on there your compression will go down slightly and it will be called a poor mans type r because the b16 head is basically the same as the type r's but a downgrade if thats what you want to call it...i say keep the head b18c head on and build up the b16 or vice versa
Old Sep 13, 2006 | 11:04 AM
B18C_DD's Avatar
Default Re: b16a or b18c head? (ViF CrX)
Not to thread jack and sorry if this is an obvious answer but.....
Why would he lose compression with a B16a head?
Would this be the same for a LS/V setup; loss of compression if using a B16 head?
Old Sep 13, 2006 | 01:09 PM
b16-bomber's Avatar
Default Re: b16a or b18c head? (B18C_DD)
yes you would lose comp with an ls/v and b16 head
Old Sep 13, 2006 | 01:13 PM
one slow coupe's Avatar
Default Re: b16a or b18c head? (b16-bomber)
you make a tad bit less compression with the b16 head beacsue the combustion chamber volume in the head is slightly larger therefore makes less compression then the gsr head..
but on the other hand the gsr head makes more compression but does not flow as well. as it is not a huge difference, b16 head flows air..
what i would do is get a b16 head and mill it to make up for the compression..
thats what i have on my lsv setup.. its milled like .036"
works good
good luck
Old Sep 13, 2006 | 01:15 PM
Default Re: b16a or b18c head? (Honda_b16a2)
you dont really wanna rev any higher then stock.. you need to pick yourself up some valvesprings..
Old Sep 13, 2006 | 05:16 PM
b20powereDA's Avatar
when u say b18c i assume ur talking about jdm itr head, so therefore, u wouldnt lose any compression by switchin to a b16 head(hence they are the same casting). and i would recommend sticking with the b18c head because it already has the stock port job on it.
Old Sep 13, 2006 | 05:51 PM
lude98SH's Avatar
Couldnt u just run a thinner head gasket for the b16 head to make up for the lower compression? Im no expert just figured i would throw that out.
Old Sep 14, 2006 | 12:19 AM
anothersickhatch's Avatar
Default Re: b16a or b18c head? (lude98SH)
why the hell would you want more compression on a motor that has over 12:1 compression anyway?
thats plenty high enough for the street in my opinion. maybe even too high. ctr pistons in a gsr block with a gsr head is WAY over 12:1. there is a thread on here that shows compression ratios of many different block/head combinations with ctr pistons.
even with the b16 head on the gsr block with ctr pistons you are looking at over 12:1.
i wouldnt even start that motor without tuning, let alone rev it to 8 or higher.
Old Sep 14, 2006 | 07:33 AM
REKOX13's Avatar
No, i am running a JDM gsr block and head. The compression is 13 to 1. I run 100 octane at all times.
Old Sep 14, 2006 | 07:44 AM
authority1's Avatar
in our drag car we used the b16 head @ first made okay power 235whp when we switched to the GSR with a lot of porting made huge power almost 300WHP
Old Sep 14, 2006 | 12:13 PM
Default Re: (authority1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by authority1 &raquo;</TD></TR><TR><TD CLASS="quote">in our drag car we used the b16 head @ first made okay power 235whp when we switched to the GSR with a lot of porting made huge power almost 300WHP</TD></TR></TABLE>
i have a feeling that had something to do with the power jump. btw, all u did was port the gsr head and jumped 65whp or did u upgrade cams, etc?
Old Sep 14, 2006 | 02:27 PM
Default Re: (b20powereDA)
i doubt that all he did was use a ported gsr head. im just a little skeptical about the fact that this motor is putting out almost 300 to the wheels and also the fact that using that head gave him 65whp. i dont see that happening.
Old Sep 14, 2006 | 04:36 PM
NA_B18C1's Avatar
for as far as i know the gsr head has the best flow and i believe it also has shorter chamber volume which gives better compression the the 16 or c5. ???
Old Sep 14, 2006 | 05:58 PM
black_EM1's Avatar
Community Builder
Community Influencer
Default Re: (NA_B18C1)
https://honda-tech.com/zerosearch
*leaves thread*
Old Sep 14, 2006 | 08:28 PM
Default Re: (black_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA_B18C1 &raquo;</TD></TR><TR><TD CLASS="quote">for as far as i know the gsr head has the best flow and i believe it also has shorter chamber volume which gives better compression the the 16 or c5. ???</TD></TR></TABLE>
this is incorrect. brad from rlz but a stock b16 head on a flow bench and it flowed about 3 more cfm than a stock gsr head. (not that 3 cfm makes that much of a difference) just stating the facts
tpdc2
Oct 5, 2007 02:49 AM
DSR!
Oct 22, 2004 07:43 AM
BorderM3
Mar 10, 2004 06:26 AM
Whatever
May 24, 2002 11:08 AM
turbopanda
May 12, 2002 10:38 PM
