Complete electrical mess
Old Sep 12, 2006 | 08:52 PM
philkehn's Avatar
Default Complete electrical mess
Well I cant get my corners to work on either side, also im not sure ive only had my rex for couple months and i barelly got it running.. are the corners suppose to light up when you turn on the parking lights or are they just blinkers or both...
Well to the point my hazard switch does not work, my to front corner lights do not work, and when i turn on my right blinker my headlights lightly flash as well my idle gets a little jumpy and the blinker does not turn on in the front, my rear right blinker flashes when i turn it on but it only flashes lightly as well, I am pretty sure I have a short somewhere.. But where to begin?
Old Sep 12, 2006 | 09:35 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: Complete electrical mess (philkehn)
To answer some of your questions: the corner light bulbs do have separate bulbs for parking and turning lights, the ones further back for p.lights, the front ones for turning, For your hazard light, check your fuse under your hood, it's most likely blown. And the other stuff is most likely a ground issue, check your grounds for the wiring coming out of your steering column, fuse boxes, pretty much everywhere. I think someone else JUST had a thread about the same problem, search around this forum a little.
Old Sep 13, 2006 | 06:18 AM
philkehn's Avatar
Hey thanks that helps alot
OneFire
12
Jun 30, 2011 06:38 PM
simplypinoyy
Jul 12, 2008 11:59 PM
Killtodie
Honda Civic (2001 - 2005)
Jun 27, 2008 03:46 PM
mister_r0b
Jul 16, 2004 10:42 AM
100bhp
Aug 9, 2003 08:24 PM
