dual zc into 88 crx si
hey guys, im helping a friend with this swap. we have a few questions: will the pm6 ecu work well enough with this? and...the swap didnt come with axles...will his stock axles work?
thanks in advanced
thanks in advanced
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamRedline89Hatch »</TD></TR><TR><TD CLASS="quote">hey guys, im helping a friend with this swap. we have a few questions: will the pm6 ecu work well enough with this? and...the swap didnt come with axles...will his stock axles work?
thanks in advanced</TD></TR></TABLE>
Yes, the PM6 will work just fine. not optimal for a DOHC ZC though, more suited to an SOHC ZC. it'll work just fine though.
His stock axles will work just fine so long as he doesn't use the DOHC ZC tranny. Any USDM d-tranny tranny will allow him to use his stock axles, but the JDM DOHC ZC tranny will require him to use 90-93 DA teg axles and remove the dust rings.
alright, well...we got the a6 out in no time! we started pulling all the wiring off of the a6 and put it on the zc, everything is connected except for the distributor wiring, thats going to be done later today. only problem we ran into...when he got the motor, it had the top piece of the manifold, didnt have the y-pipe, so we tried to use his stock a6 manifold...didnt fit. the bottom right of the flange hits the motor, so it wont seal against the head. my buddy wants to just get some ebay headers for now, until he makes up his mind on going boost or not...if he were to order them for the 88-00 d series, itll bolt right up, right? ill get some pics tomorrow
thanks in advanced!
thanks in advanced!
get the PM7 ecu its the best one. also the axles will work and as far as header you can grind your D15 header and make it work. Same bold pattern just put the gasket up on the header and grind away. works good.
Glowicki
Oct 1, 2011 12:11 PM
kanzenr91si
Feb 16, 2004 02:34 PM
for tippyman
