EF Fuel pump question.
Old Sep 12, 2006 | 08:26 PM
z6_EF_obd1's Avatar
Default EF Fuel pump question.
Okay, I know I read this somewhere in here but I can't find it.
I need to replace my fuel pump cuz I have the stock 90 STD hatch pump. MY engine is a d16z6 with a 12:1 CR.
I know that 92-00 pumps are bigger, does anyone know the difference in lph or psi? or if the 88-91 si is the same size? and will the 92 and up fit? I promise I'm still searching!!!!
Old Sep 13, 2006 | 02:17 AM
crxnj's Avatar
Default Re: EF Fuel pump question. (z6_EF_obd1)
sohc vtec,sohc nonvtec and dohc non vtec all have the 79lph fuel pump..The dohc vtec has 135lph...so its not an upgrade at all unless you're getting one from a 99-00 si or gsr,type-r etc...And then they dont bolt right in anyway,,it takes some rigging......
Maybe the 92-93 gsr fuel pump fits perfect but im not sure at all with that so dont listen to me.
Old Sep 13, 2006 | 06:12 AM
z6_EF_obd1's Avatar
Default Re: EF Fuel pump question. (Mr.speaker)
But aren't the fuel pumps from dpfi EF's smaller due to the 2 injectors rather than 4? If answer is still no, Should i just get an after market one?
Old Sep 13, 2006 | 07:09 AM
y-49's Avatar
i got a walbro 255 lph one ill sell
Old Sep 13, 2006 | 01:24 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6_EF_obd1 &raquo;</TD></TR><TR><TD CLASS="quote">But aren't the fuel pumps from dpfi EF's smaller due to the 2 injectors rather than 4? If answer is still no, Should i just get an after market one? </TD></TR></TABLE>
nope,it flows the same 79lph..as far as a upgraded fuel pump thats up to you,,dont know how much power your soch is making but i honestly doubt you need a different fuel pump since there are people that have type-r motors,gsr's,lsvtec,etc with stock pumps,,
Old Sep 13, 2006 | 01:27 PM
Boosted Chemist's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6_EF_obd1 &raquo;</TD></TR><TR><TD CLASS="quote">Okay, I know I read this somewhere in here but I can't find it.
I know that 92-00 pumps are bigger, does anyone know the difference in lph or psi? or if the 88-91 si is the same size? and will the 92 and up fit? I promise I'm still searching!!!!</TD></TR></TABLE>
if your pump aint broke, u dont need to replace it, i made 280 whp on the stock 88 si pump.
Old Sep 13, 2006 | 02:07 PM
z6_EF_obd1's Avatar
Default Re: EF Fuel pump question. (Boosted Chemist)
Okay well, I replaced my stock FPR for another one with the B&M comand flow adjustable part. My stock reading was 30 psi and i raised it to 38 but it won't go higher than that. I figured it could be my pump, since i remembered it was smaller.
Let's say it's not smaller and i read wrong. If so, why did i have a reading of 30 psi when it's should be 40? I tried 2 FPR's and 2 gauges and they all gave me the same result. What can be causing my pressure to be so low?
Old Sep 30, 2006 | 12:32 PM
4gencivicef9's Avatar
I like to know too?
HWKR3W
Jan 12, 2011 05:14 AM
HWKR3W
Jan 11, 2011 07:20 PM
MonKK
Mar 14, 2009 11:52 PM
Ruby Civic
Aug 27, 2003 03:41 PM
