ABS Light
Old Sep 12, 2006 | 06:56 PM
EXccord's Avatar
Default ABS Light
I have 109k on my 95 accord, been doing alot of highway. Anyhow, just recently my ABS light has been kicking on after about 5 minutes of starting my car up. It turns on when i either, let my car warm up after about 5 minutes or when i go faster than 20mph, the light just kicks on, my brakes are fine...i looked for a search on abs/abs light/etc... only came up with people talking about working out, which really doesnt help me out in this situation..anyhow, is this some kind of "go to a honda dealership and get it reset" deal or what? As far as i know the only "attempt #1" to fixing it would be to reset the ecu by unplugging the battery for like 10-15 minutes...can anyone help me out here?
edit: forgot to mention that my abs brake fluid as well is at the level that it is recommended to be at and such...so i honestly dont know what the hell is wrong with this light, its kind of annoying, would honestly hate to have a swap that causes your CEL to stay on
Modified by EXccord at 11:33 AM 9/13/2006
Old Sep 13, 2006 | 12:05 PM
honda_kid42's Avatar
Default Re: ABS Light (EXccord)
there is a way to check it...there should be a blue plug under your glove box, jump that with a paper clip or wire and then turn your ignition to the on position (do not crank the engine over) and the ABS light should blink and give you a code...then search for that code on here and it will tell you whats wrong! good luck
Old Sep 13, 2006 | 09:56 PM
H22CD's Avatar
All I did when my ABS light came on was give it more brake fluid and it went away and never SHOWED again. It's been 6 months.
Old Sep 14, 2006 | 06:34 AM
Honda-Master's Avatar
Default Re: ABS Light (R34CD5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R34CD5 &raquo;</TD></TR><TR><TD CLASS="quote">All I did when my ABS light came on was give it more brake fluid and it went away and never SHOWED again. It's been 6 months. </TD></TR></TABLE>
daaaaaaaaaaaaaaaa ,,,, did you not read that he said the brake fluid was ok......?
he needs to pull the code like honda kid said , so it can be diagnosed ,
Old Sep 14, 2006 | 05:23 PM
H22CD's Avatar
Default Re: ABS Light (Honda-Master)
haha. You're dumb. Of course I read it. I was just saying as if WHY IT DID'NT WORK ?
Why do people always got to play tough behind a computer screen and try to make people sound stupid ? You probably would'nt have the ***** to approach me that way if I were in the flesh. to you.
Old Sep 14, 2006 | 06:29 PM
EXccord's Avatar
lol cmon now guys lets not e-thug it ..lets all be e-friends here haha. Anyways ill check the code when i can...
00n0908
Sep 11, 2016 09:39 AM
laurn
Suspension & Brakes
Feb 18, 2013 07:30 AM
94coupeNA
Jan 26, 2006 12:56 PM
